Thread: carbon monoxide detector
03-05-2010, 04:21 AM #1
Opinion? Gas furnace, gas hot water heater in attic of newly built home. Would a CO detector?
03-05-2010, 06:38 AM #2
Re: carbon monoxide detector
If you are asking should a CO detector be installed in the house my answer would be yes. I think you are wondering because the equipment is in the attic which is not living space.
The thing to realize is this. If a heat exchanger cracks, the CO can be introduced into the supply air coming from the air handler. Regardless of where the equipment is located, a malfunction can still introduce CO gas into the living space.
03-05-2010, 08:36 AM #3
Cobra,
I would still recommend a CO detector. However, I would also advise that the CO detector sound a warning at 5 - 9 ppm CO not the standard 75 ppm CO detectors that you buy at the big box stores. The Co standard now only "allows" 9 ppm in the home's ambient air.
03-07-2010, 09:32 AM #4
03-07-2010, 12:26 PM #5
Robert,
Try the National Comfort Institute.
03-07-2010, 06:01 PM #6
03-08-2010, 05:28 PM #7
The NCI model displays a visual reading at 5 PPM and alarms at 15 PPM, at 70 PPM it can't be shut off.
The alarm standards the NCI model uses are all based off of world health organization standards.
The CO Experts has no delay on it so if it sees a quick spike of CO it will go off at 10 PPM.
Both are great models and offer true protection.
