Thread: Window Hazards
    Jim Dull's Avatar
    Jim Dull Guest
    Default Window Hazards
    These windows are about 2 feet from the ground. They require safety glazing. Right? They are in every room of the upstairs.
    Corpus Christi, TX
    Default Re: Window Hazards
    No Jim. For safety glass to be required in your example, it would have to meet ALL of the following:
    • exposed area of gazing>9sq ft
    • bottom edge<18 inches
    • top edge > 36 inches above floor
    • within 36 inches horizontal of walking surface
    Even when all those exist, if a minimum 1 1/2 inch high protective barrier is constructed at 34 to 38 inches above the walking surface, the safety glazing is not required.
    - Paul Fix
    Quote Originally Posted by Thom Walker View Post
    This is the key one here in most cases.
    That mean 'ONE SINGLE' pane is that large. Not the entire window opening.
    Jim Dull's Avatar
    Jim Dull Guest
    Thanks guys.
    Richard Rushing's Avatar
    Richard Rushing Guest
    Hello Jim,
    For future visual reference, here are a couple of illustrations to add to your library to glance at when the need should present itself:
    (see attachments)
    Richard
    Jim Dull's Avatar
    Jim Dull Guest
    Thanks Richard. That is very helpful.
