Thread: Composite Siding
07-02-2007, 02:40 PM #1
Composite Siding
07-02-2007, 03:44 PM #2
07-02-2007, 04:27 PM #3
Re: Composite Siding
There should be a flashing if the banding board is set on top and not under the siding layer above.Which would cure the rotten pooling problems.
07-02-2007, 04:43 PM #4
I'll re-phrase that to: The banding board should NOT be set *on top* of the siding.
The flashing, if installed correctly, will go up behind the siding above and down and out over the band trim, turning downward. The siding should also have at least 1/4" gap (maybe even more) between the bottom of the siding and the 'Z' flashing.
If flashed that way, the band (trim) piece is no longer 'on top' of the siding, the siding behind it is simply 'a shim' used to add an architectural depth to it.
Of course, though, *the damaged siding* should have been cut out and replaced - meaning that to do it properly, there is no siding 'to go on top of' ... its been removed.
