Results 1 to 11 of 11
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Flashin caps, not needed?
    East Bridgewater, MA
    Wink Re: Flashin caps, not needed?
    Quote Originally Posted by Jeff Eastman View Post
    Would you agree that flashing caps are not needed on top of the casement trim ?
    Hello Jeff,
    The windows may be a self-flashing type, in which case your report should have a caveat for risk management. However the top trim boards should still have z-flashing.
    Bob Mulloy
    Default Re: Flashin caps, not needed?
    Quote Originally Posted by Clay E White View Post
    Z-flashing above the trim boards required? Please provide reference. I never write that up -- doesn't mean I'm right but I certainly haven't been noting the lack of the Z.
    Observation: Metal Z-shaped flashing is missing between the intersection of a horizontal trim board above a window and the adjacent siding.
    Analysis: Metal z-flashing should be present above all horizontal trim boards to prevent water infiltration. The flashing should extend under the siding and then downward with a right angle bend over the top edge of the wood trim, and a final right angle bend over the face of the trim board. When z-flashing is missing, there is a risk of water infiltration, concealed damage, decay, and mold and pest infestation. Repair is needed.
    Recommendation: I advise that you hire a carpenter to install metal z-flashing wherever missing.
    David Banks's Avatar
    David Banks Guest
    I like that Bob. Mind if I use it?
    Bob, great verbiage.....what's your reference in code , though, to support your position?
    Clay,
    Things like that don't need support from code or not code, they are "common sense" and *used to be* "good construction practice".
    Think like water, ask yourself 'Can I get in there?', if 'yes', it needs a flashing, or a better flashing, or whatever it is you are seeing/not seeing.
    Apr 2007
    gainesville fl
    For some reason In this area I think the alphabet stopped at Y because there is not much Z flashing installed, I write it up as being done improperly and that the caulk should be monitored until a proper flashing can be installed.
    Jerry, do they use much Z over on the coast or just caulk.
    Quote Originally Posted by bruce m graham III View Post
    I was in Gainesville for 20 years, from 1967 to 1987, 'Z' flashing was almost always used back then.
    I think it's more of the builders now thinking 'I can save 50 bucks per house, and by the time a leak is discovered, I'm way out of the picture.', but they are not aware of Chapter 95.
    From what little of that I've looked at, it's hit or miss here, I think mostly depending on age of the house. Older ones were more often done correctly, newer ones more not.
    To be truthful, I don't remember is the house we bought a year and a half ago here, built in 1978, has 'Z' flashing or not - guess I'll need to look and see.
    Corpus Christi, TX
    You should have hired an inspector.
    - Paul Fix
    Quote Originally Posted by Thom Walker View Post
    I did.
    But, like most buyers, I don't remember everything which was discussed.
    Don Matthews's Avatar
    Don Matthews Guest
    Talking Re: Flashin caps, not needed?
    Up here in the North, the AHJ will fail a house during the dry-in inspection if he doesn't find Z-flashing above the windows. The only windows I am familiar with that have the factory applied Z-flashing are the ones that are metal framed. It is visible above the window even after the trim boards are applied.
    Quote Originally Posted by David Banks View Post
    Be my guest, that is why I posted the text.
