Results 1 to 16 of 16
07-27-2010, 07:00 PM #1
Wood frame for Mobile Home Skirting
Hello.
I just inspected my first mobile home and it had untreated 2x2 wood supporting the vinyl skirting around the exterior. Along the bottom of the skirting courses, the wood was in contact with the (commonly wet) ground. How common is this? Should I recommend it be replaced to reduce conditions conducive to WDO's?
Thanks.
07-27-2010, 08:03 PM #2
Re: Wood frame for Mobile Home Skirting
Absolutely! Any wood within 18" of the ground is required to be rot resistant. Also remember there are different types of "treated" wood. Recommend treated wood that can be in contact with the earth.
07-27-2010, 09:24 PM #3
Wayne, let's assume this is residential construction and not a manufactured home.
Do you have an IRC code cite I can look into for this? Reason I ask is that in the land of post and beam construction, our posts are typically much closer than 18" off of the ground, and are not PT or decay resistant wood.
07-27-2010, 09:33 PM #4
Hi Luc,
Yes it is a problem that should be called out and yes it is very common. If you continue to inspect mobile homes or older homes with crawlspaces, you will see untreated wood in contact with soil. I always call it out and recommend repair to prevent wood decay and attracting wood destroying insects in and around the structure.
07-28-2010, 06:05 AM #5
Brandon, here ya go!
And here is a link to the ICC codes online.
International
SECTION R319
PROTECTION AGAINST DECAYR319.1 Location required.Protection from decay shall be
provided in the following locations by the use of naturally
durable wood or wood that is preservative treated in accordance
with AWPA U1 for the species, product, preservative
and end use. Preservatives shall be listed in Section 4 of
AWPA U1.
1. Wood joists or the bottom of a wood structural floor
when closer than 18 inches (457 mm) or wood girders
when closer than 12 inches (305 mm) to the exposed
ground in crawl spaces or unexcavated area located
within the periphery of the building foundation.
2. All wood framing members that rest on concrete or
masonry exterior foundation walls and are less than 8
inches (203 mm) from the exposed ground.
3. Sills and sleepers on a concrete or masonry slab that is in
direct contact with the ground unless separated from
such slab by an impervious moisture barrier.
4. The ends of wood girders entering exteriormasonry or concrete
walls having clearances of less than 0.5 inch (12.7
mm) on tops, sides and ends.
5. Wood siding, sheathing and wall framing on the exterior
of a building having a clearance of less than 6 inches (152
mm) from the ground.
6. Wood structural members supporting moisture-permeable
floors or roofs that are exposed to the weather, such
as concrete or masonry slabs, unless separated from such
floors or roofs by an impervious moisture barrier.
7. Wood furring strips or other wood framing members
attached directly to the interior of exterior masonry walls
or concrete walls below grade except where an approved
vapor retarder is applied between the wall and the furring
strips or framing members.
07-28-2010, 11:26 PM #6
Thanks Wayne,
I'm a little worn out right now, but don't see interior crawlspace posts covered, so I guess it's alright to stick them just about at grade level...
If a MFGH was considered a residential structure and built per the IRC, I would say the clearance requirement for untreated wood/ skirting materials would be 6"Any wood within 18" of the ground is required to be rot resistant.
Also, thanks for the link. I try not to read too much from anything but Oregon's code (ORSC) which is available on- line as well. I used to study both, but started confusing myself.
07-29-2010, 07:08 AM #7
I think this would be the pertinent section.5. Wood siding, sheathing and wall framing on the exterior
07-29-2010, 07:33 AM #8
I would not be so quick to condemn the skirt frame. Just tell them to maintain it.
The skirt is temporary, and needs repair from time to time. It is a mobile home, right?
But, we have the less aggressive termites in my area, so the wood can become quite rotten and still be termite-free.
In Washington state, I would do a little research. Some parts have dampwoods, some have subs.
Last edited by John Kogel; 07-29-2010 at 07:45 PM. Reason: clarifying my cavalier atitude :)
07-29-2010, 11:37 AM #9
07-29-2010, 02:17 PM #10
Agreed.5. Wood siding, sheathing and wall framing on the exterior
07-29-2010, 02:46 PM #11
07-30-2010, 07:17 AM #12
Maybe maybe not. Just because someone calls it a mobile home does not mean that it IS a mobile home. You do know that there are structures that look like mobile homes that are not mobile homes don't you?
But you are correct that building codes do not apply to mobile homes. Well not the building codes that everyone references anyway. There are building codes, just not the ones we are used too.
Besides HI's do not use codes. So a HI can call out anything they feel is not kosher. And I don't mean a pickle. Well I guess it could be a pickle, like getting in a pickle, but that would be hard to get in a pickle...that would be like the pretzle in the M&M. Have I lost you guys yet?
07-30-2010, 08:14 AM #13
08-02-2010, 07:17 AM #14
As far as I'm concerned, code is irrelevant. That doesn't mean it isn't a good general guideline, but it is outside inspection standards and authority. What if you are inspecting a structure that was built before codes existed and it has wood in the soil. Are you going to not call it out as a concern because it is grandfathered with NO code? Of course not. We inspect to accepted best modern building practices and safety regardless what, if any, code existed when it was built. Who can keep track of what the code was, if any, when every house was built and which one is being used in each jurisdiction, and how the individual government code inspector interpreted it? It's practically impossible. Stick to inspection standards and use your own building knowledge and experience and good sense. And, if you don't have hands on building experience, good luck!
Brent Lerwill, Coos Bay, Oregon
08-13-2010, 04:15 AM #15
I understood it a bit.Wanna add more light on it.
FHA loans are available to anybody but are used most often by first-time home buyers and low- to moderate-income buyers.
08-13-2010, 08:13 AM #16
You're doing pass / fail inspections ? Under whose authority ?
All we're doing is noting conditions of concern. I would guess probably 60% of the mobiles have some rotted framing at lower edge(s) of the skirting.
It doesn't fail... it simply is what it is... note it and move on dot com
