Thread: Gap at siding transition
09-26-2010, 12:10 PM #1
What type of trim should be at this gap between the old aluminum siding and wood siding above the trim board?
Do they make a type of J channel or similar?
09-26-2010, 01:12 PM #2
Re: Gap at siding transition
It looks like "Z" trim could work.
09-26-2010, 01:52 PM #3
I agree with James; the piece would most likely have to be custom made to fit correctly and be installed before the metal siding is put on.
09-26-2010, 02:07 PM #4
I agree with James and Jon...
Best
Ron Bibler
Santa Rosa Pest Control - Inspection and Pest Control in Sonoma County
09-26-2010, 04:47 PM #5
It looks like it would be a perfect install if the Z-metal flashing were there. The problem is usually in the other direction... getting the installer to leave the gap at the lower edge of the siding rather than just installing it tight.
09-27-2010, 04:18 AM #6
Thank you everyone..
