11-02-2010, 11:38 AM #1
ASTM E2112, Standard Practice for Installation of Exterior Windows,Doors....
ASTM E2112, Standard Practice for Installation of Exterior Windows,Doors and Skylights
I just spent about 10 minutes searching for this document with no luck...anybody have a source or copy of this they could share?
11-02-2010, 01:58 PM #2
Re: ASTM E2112, Standard Practice for Installation of Exterior Windows,Doors....
I figure you are trying to get it without paying the fee, good luck. But just in case you are willing to purchase it look here: ASTM E2112 -07 Standard Practice for Installation of Exterior Windows, Doors and Skylights
11-02-2010, 02:31 PM #3
Google this:
.pdf Standard Practice for Installation of Exterior Windows,Doors and Skylights
Then look at the URL's (in green) and click on the ones with a .pdf at the end
This one is based on the ASTM doc and may have all that you need:
pro.milgard.com/_doc/products/installation/pdf/aama-2410-03.pdf
www.BAKingHomeInspections.com
11-02-2010, 03:49 PM #4
Thanks for the replies.
Yes, I was hoping to find it online for free somewhere. I had looked through the first 10 pages of google searching for it with no luck.
I want to get a look at it because I've had a run on poorly installed windows lately and tomorrows inspection is a new house with vinyl siding. I have the good fortune of never having had to work with vinyl in my long carpentry career and my knowledge base is a little light on that fine cladding material.
I was studying the Vinyl Siding Institutes Installation Manual and they reference the ASTM document for new construction.
Flashing New Window Installationsinstructions and ASTM E2112, Standard
If installing both a new window and
flashing, refer to window manufacturer’s
Doors and Skylights for the proper flashing
installation method for the window type and
wall configuration on the project.
I was trying to determine if in new construction with properly installed windows and vinyl siding would any flashing be visible in addition to the J channel along the head of the windows.
Can anyone educate me on this?
11-02-2010, 04:46 PM #5
ASTM E 2112-01
11-02-2010, 05:06 PM #6
Thank you Jerry....
