Results 1 to 3 of 3
    Jul 2010
    Washington
    Default Particle Board Siding
    I inspected a split level 1977 home today that had an assortment of siding materials in use. Under one window section there was about 6' of a particle board siding panel. Along the cut edge on the bottom there was excessive moisture and I plan on writing it up as such. I don't have much experience here so I wanted to know what others know about particle board siding and if there are any specific products that have been known to perform worse than others.
    F.I.R.E. Services
    Default Re: Particle Board Siding
    Does not matter if it's:
    Masonite, Fiber board, particle board, chip board, composite, Abitico, hard board or what ever, it's all Crap board.
    Such siding is high maintenance. Once water gets into it the board begins to swell and there's not much you can do with it when that happens. Contractors/builders who put that stuff on are not doing anyone any favors - except the guys who come back in to rip it out out when it decays. I looked at a 9 yr old 4,000 SF house yesterday trimmed out in the stuff - most of it was turning to mush.
