04-04-2012, 03:05 AM #1
Cedar posts in contact with paved surfaces
Is cedar considered naturally decay resistant enough to be placed in contact with paved surfaces like at a front porch column, or must they be placed on a plinth block like non-treated pine?
04-04-2012, 08:55 AM #2
Re: Cedar posts in contact with paved surfaces
Anytime you stand it on it's end grain it acts like a sponge. Pressure treasted or not.
Block is always a good idea.
As far as requirement. I would call you're local building dept for their take on it.
04-04-2012, 11:28 AM #3
You should use one of these regardless of lumber type.
Shop Simpson Strong-Tie 4 x 4 Standoff Post Base Z-Max at Lowes.com
04-04-2012, 03:49 PM #4
Depends.
Most cedar is not considered naturally decay resistant, but some is:
- From the 2006 IRC:
- - NATURALLY DURABLE WOOD. The heartwood of the following species: Decay-resistant redwood, cedars, black locust and black walnut.
- - - Note: Corner sapwood is permitted if 90 percent or more of the width of each side on which it occurs is heartwood.
For information on heartwood, go here:
http://northernwoodlands.org/article...and_heartwood/
Wood - Wikipedia, the free encyclopedia
Nick is correct.
04-04-2012, 06:56 PM #5
04-04-2012, 06:57 PM #6
best to know the post size and load
4x4 may be inadequate for material dimension and intended purpose
AB/ABA/ABE/ABU Adjustable and Standoff Post Bases
