Results 1 to 9 of 9
    Aug 2010
    BC Canada
    Default what is this siding?
    what is the trim covered siding? formed panel? stucco?
    Mar 2011
    Sparks,NV
    Default Re: what is this siding?
    It's probably that stucco panel or stucco board. Just 4x8 sheets embossed to look like stucco.
    Nevada IOS#1730
    Nevada Energy Auditor #30
    775-342-4767 www.homecsi.com
    Quote Originally Posted by Robert Ernst View Post
    There were skim coated 4x8 panels as well.
    Darrel Hood's Avatar
    Darrel Hood Guest
    There are trim products for stucco that are carved styrofoam forms. Perhaps that's what these are.
    Jan 2009
    San Antonio, TX
    Older homes here in TX used a Masonite type panel that was stamped to look like stucco. These panels would last only if you keep them caulked and painted. Otherwise, water gets to it and it falls apart just like the Masonite panels that rot at the joints and the base by the ground from water splash off the roof.
    Dominiclp's Avatar
    Dominiclp Guest
    Quote Originally Posted by Ray Babcock View Post
    so Peter it has been a while since your post. but, did you ever get a confirmation of the siding. to me it looks like stucco with EIFS bands. considering that the base of the column looks like stone veneer that would be adhered to stucco
    New York
    I am unable to enlarge these photos, and haven't a clue as to what is there. All I see is grey.
    I suggest you poke around and determine what is under the paint. (is there eps? plywood? masonite?), etc.
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    Capistrano Beach, CA
    Quote Originally Posted by Steven Turetsky View Post
    Steven, try holding down your "Ctrl" key and hit your "+" key several times to zoom in. Ctrl and - to zoom out.
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Aug 2010
    BC Canada
    Quote Originally Posted by Dominiclp View Post
    I just say it stucco panel.
