Results 1 to 3 of 3
    Default Garqage Door Inspection Help
    Many may look at a garage door during an inspection but may not really see what is going on with its many elements. Here is a point many may over look.
    The connection of the spring to the bracket. First pict incorrect & 2nd is corrected.
    Default Re: Garqage Door Inspection Help
    Better inspectors will inspect the door before crushing the door.
    Made a quick tabulation and came up with 42 general items to check before thinking about opening the door. Much less testing/inspecting/operating any function of the doors operation.
