    Iowa City, IA
    Default Vertical Vinyl Siding
    The siding on this home was installed vertically. I was not there doing a home inspection, and did not get a chance to check to see what was behind the vinyl. The home was built in 1991, so it may or may not be original. Long enough pieces appeared to have been used that no horizontal seams existed (i.e. span from foundation to eave). The exception would be at the tall gable ends where J channel was used at a single horizontal seam (at the base of the triangular shape gable wall) between the upper and lower pieces. Has anyone seen vinyl installed in this manner? Opinions? Concerns?
    http://i303.photobucket.com/albums/n...ertsiding1.jpg
    http://i303.photobucket.com/albums/n...ertSiding2.jpg
    http://i303.photobucket.com/albums/n...ertSiding3.jpg
    F.I.R.E. Services
    Mar 2012
    North Central Texas
    Default Re: Vertical Vinyl Siding
    Quote Originally Posted by Andrew Kolar View Post
    Installation FAQ - VSI - The Vinyl Siding Institute
    Texas Inspector
    http://www.texasinspector.com
    Oct 2010
    Tolland, CT
    there is verticle vinyl siding. it comes in different patterns. the difference is regular horizontal siding has weep holes to let moisture out on the bottom. verticle does not it lets moisture out of the bottom into the J channel or other trim.
    Mike
    From those pictures I see no concerns. Vinyl siding is not intended to be a water tight barrier - what's behind the vinyl is where you need to have the proper details for water management.
