    Daniel Island, SC.
    Default What kind of stucco siding is this
    Did an inspection of a 1995 house that has a stucco exterior. Looking at it from a chipped area showed that their was a thin veneer plywood on the outside with the stucco applied, a one inch foam core and then another thin veneer that appeared to fiber-glassed or reinforced. Can any one identify this?
    Thanks, Jim
    New York
    Default Re: What kind of stucco siding is this
    I believe you are describing EIFS
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    Daniel Island, SC.
    No, I do not think it is EIFS because it has a backing. It is like the foam core is sandwiched between the two veneers
    Jim
    Quote Originally Posted by JIM MURPHY View Post
    Jim
    Jim,
    As Steven said, that is EIFS - Exterior Insulation Finish System - one in which someone applied plywood to the exterior then stuccoed the plywood, but Exterior Insulation nonetheless.
    I do not see much EIFS, but if the insulation (that foam core) is on the exterior, it is an EIFS, maybe not a manufactured system, but still EIFS.
    I'm sure that Steven, Scott, or some of the others who see and inspect EIFS all the time will know what type of EIFS it is.
    Daniel Island, SC.
    Thanks Guys, I really appreciate it. I do not see much or any of it here.
    Jim
