Results 1 to 16 of 16
    New York
    Default Name this roof...
    If I had to name this roof, I would probably call it Shirley, but that's me. What would you call it?
    I know it is a clerestory window, but what would this type of structure/roof be called... raised dorma? shed?
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    Default Re: Name this roof...
    Quote Originally Posted by Steven Turetsky View Post
    That is called a Skillion roof.
    Jul 2010
    Wisconsin
    I've seen similar, and designers referred to the structure (or roof) as a contemporary or modern design. Roofers refer to them as something you step in, with flat areas and roof pitches out of nowhere.
    I would ....call it Shirley, but that's me.
    Hi Shirley.
    Scott is most correct. A sloping roof, often not attached ......
    "Skillion roofs can also be used to provide clerestory windows for a hallway or similar room where a row of windows is placed below the edge of the skillion section reaching above the other roof below".
    I would call it a shed roof to avoid superiority issues, but that's me. They did a poor job of flashing, eh?
    New York
    Thank you so much
    What are these and Why are they there ?
    New York
    Do you mean these?
    So, by definition, all sloping roof surfaces are called Skillion roofs ...
    There are two Skillion roofs meeting at the ridge of a gable roof; there are four Skillion roofs meeting at the hip ridges for hip roofs; two Skillion roofs not attached to each other and not meeting each other with one above the clerestory windows and one below them; etc. ...
    Normally, those roofs would be called "shed" roofs ...
    Do you mean these?
    That Be Them.
    New York
    I didn't look at them closely, but I would say alarm related.
    John Ritter's Avatar
    John Ritter Guest
    Non Hip "other"
    Aug 2009
    rockport texas
    Is kickout / diverter flashing required where the roof terminates at the stucco?
    Quote Originally Posted by stanley frost View Post
    Yes ... unless you can figure out some other way to make sure that no water enters that junction where the roof end "in" the stucco.
    New York
    I don't know about a kickout flashing, but I would certainly like to see more (higher clearance than what is already there) flashing (or a cricket of sorts), and flashing around the trim in order to create a sealable joint the entire way around the roof edge/chimney transition.
    I also recommended removing the old clerestory windows and building a curb (minimum 2"-4" high) under the windows that could be flashed and sealed.
    Ft. Myers, FL
    Quote Originally Posted by John Ritter View Post
    Non Hip "other"
    I dont think they are familiar with the 1802 form...
    Paul Kondzich
    Ft. Myers, FL.
