Results 1 to 16 of 16
Thread: Name this roof...
11-23-2012, 02:47 PM #1
Name this roof...
If I had to name this roof, I would probably call it Shirley, but that's me. What would you call it?
I know it is a clerestory window, but what would this type of structure/roof be called... raised dorma? shed?
11-23-2012, 04:09 PM #2
Re: Name this roof...
11-23-2012, 04:40 PM #3
I've seen similar, and designers referred to the structure (or roof) as a contemporary or modern design. Roofers refer to them as something you step in, with flat areas and roof pitches out of nowhere.
11-23-2012, 04:42 PM #4
Hi Shirley.
Scott is most correct. A sloping roof, often not attached ......
"Skillion roofs can also be used to provide clerestory windows for a hallway or similar room where a row of windows is placed below the edge of the skillion section reaching above the other roof below".
I would call it a shed roof to avoid superiority issues, but that's me. They did a poor job of flashing, eh?
11-23-2012, 06:04 PM #5
Thank you so much
11-23-2012, 06:20 PM #6
What are these and Why are they there ?
11-23-2012, 06:44 PM #7
Do you mean these?
11-23-2012, 06:57 PM #8
So, by definition, all sloping roof surfaces are called Skillion roofs ...
There are two Skillion roofs meeting at the ridge of a gable roof; there are four Skillion roofs meeting at the hip ridges for hip roofs; two Skillion roofs not attached to each other and not meeting each other with one above the clerestory windows and one below them; etc. ...
Normally, those roofs would be called "shed" roofs ...
11-23-2012, 08:07 PM #9
11-23-2012, 08:33 PM #10
I didn't look at them closely, but I would say alarm related.
11-24-2012, 05:31 AM #11
I would say shed too.
Skillion roof - Wikipedia, the free encyclopedia
Roof Construction
11-24-2012, 08:00 AM #12
Non Hip "other"
11-26-2012, 06:15 PM #13
Is kickout / diverter flashing required where the roof terminates at the stucco?
11-26-2012, 06:37 PM #14
11-27-2012, 06:54 AM #15
I don't know about a kickout flashing, but I would certainly like to see more (higher clearance than what is already there) flashing (or a cricket of sorts), and flashing around the trim in order to create a sealable joint the entire way around the roof edge/chimney transition.
I also recommended removing the old clerestory windows and building a curb (minimum 2"-4" high) under the windows that could be flashed and sealed.
11-27-2012, 12:52 PM #16
