Thread: Safety glass?
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Re: Safety glass?
    If the "exposed area" (IRC language) of that bottom pane is 35 inches wide and it is square, then it isn't greater than 9 square feet and so wouldn't have to be safety glazed.
    Garland, TX
    and to expand on Jonh's information the window pictured is not an equally sized upper and lower sash therefore the lower sash would be less than 35" tall/high. Non-tempered OK by code but a simple advisement to your client should not be questionable.
    Quote Originally Posted by BARRY ADAIR View Post
    Hey, no fair. You're using arithmetic!
    Garland, TX
    Nope, just looked and top was bigger, just like I like 'em.
    BTW with this post I've reached my boiling point.
    215? You must be below sea level.
    Hey, wait a minute. The posts aren't being added up. I have two that say Posts: 406 and you have two that say Posts: 215. What the ...?
    Now I'm really confused. Since I posted on another thread, now all my posts on this thread say Posts: 407!
    I'm taking a nap.
    Last edited by John Arnold; 09-26-2007 at 02:36 PM. Reason: Adding inane comments.
