Thread: Illuminated Concrete
03-14-2013, 03:12 AM #1
Texas Inspector
http://www.texasinspector.com
03-14-2013, 07:43 PM #2
Re: Illuminated Concrete
Very neat!
I wonder how the strength of the concrete is affected? Weaker? Or possibly even stronger like fiber-reinforced concrete?
Is there a moisture intrusion path in around the fibers?
And more ponderables ...
03-15-2013, 07:30 AM #3
Major bridges carrying vehicles are built around the world [including USA] with spans containing NO rebar. Google "DUCTAL concrete bridge". These bridges use steel fibers.
LED concrete - stronger or weaker - depends on the application. If LEDs were only embedded on one side, and the remaining concrete was properly engineered for the structural application; no problem [even LEDs on two sides with structural concrete sandwiched for the application].
"Moisture intrusion path" - all concrete is a ***galaxy of moisture intrusion***. The LEDs would probably not be an addition to the existing problem. For example: Xypex is an excellent product; used world wide in billion dollar dam and waterfront projects. If used properly Xypex stops water, but I do not believe that even Xypex makes a claim of stopping all water VAPOR [also other chemical vapors] . Therefore GREEN REBAR [epoxy-coated reinforcing bar (ECR)] is necessary in some projects - maybe you have seen this on new or rehab highway/bridge projects. That is epoxy rebar. Precautions/additives in the concrete mix can never properly protect the rebar from corrosion, therefore the projects fail only because of the rebar rusting and/or corroding away. The Green Rebar is the best way to get the proper life span [concrete recipe must still be correct].
Please note: I have no building/construction industry affiliation. I am a homeowner who loves this site, and who never sees a house built correctly; especially the foundation. Home Owners / Designers / Architects put 99% of their thought into paint colors and Less than 1% [optimistic #] into the foundation [the # is probably Zero].
Great Site,
David.
PS: "all concrete is a ***galaxy of moisture intrusion***" is my writing; it is not a quote from a book.
03-15-2013, 07:45 AM #4
Texas Inspector
03-15-2013, 09:12 AM #5
I like that thought pattern, but actually it was along a different line.
For example: consider the expanded carbon filtration media used in water and air filtration. Take just 1 gram [0.036 ounce] of expanded carbon and theoretically open up all the pores in the carbon across a flat surface. The internal area of those pores in one gram would cover the surface of a Football Field. Different concrete mixes with different mixing and placement techniques have varying level of pores for migration, but it is still a phenomenal amount of pores for moisture.
Best to you,
David.
