Thread: Safety glass?
09-26-2007, 12:13 PM #1
Safety glass?
09-26-2007, 12:24 PM #2
Re: Safety glass?
If the "exposed area" (IRC language) of that bottom pane is 35 inches wide and it is square, then it isn't greater than 9 square feet and so wouldn't have to be safety glazed.
09-26-2007, 01:03 PM #3
Re: Safety glass?
and to expand on Jonh's information the window pictured is not an equally sized upper and lower sash therefore the lower sash would be less than 35" tall/high. Non-tempered OK by code but a simple advisement to your client should not be questionable.
09-26-2007, 01:06 PM #4
Re: Safety glass?
09-26-2007, 01:18 PM #5
Re: Safety glass?
09-26-2007, 02:05 PM #6
Re: Safety glass?
215? You must be below sea level.
Hey, wait a minute. The posts aren't being added up. I have two that say Posts: 406 and you have two that say Posts: 215. What the ...?
Now I'm really confused. Since I posted on another thread, now all my posts on this thread say Posts: 407!
I'm taking a nap.
Last edited by John Arnold; 09-26-2007 at 02:36 PM. Reason: Adding inane comments.
