Results 1 to 2 of 2
Thread: Efflorescence on Bricks
03-24-2013, 06:30 AM #1
Other than commenting not to have the sprinkler systems spray onto the house, do you folks comment on the efflorescense itself?
03-24-2013, 09:43 AM #2
Re: Efflorescence on Bricks
Depends on wall condition. If eroded, then I recommend pointing or replace spalled bricks.
For that wall once the water stops hitting it, the wall should be fine. As you eluded to, a basic comment would be 'redirect sprinkler heads and point wall areas as determined'. The ground slope looks pretty good from the pic so I doubt the concrete foundation will suck up much. You could always recommend painting the concrete wall but there are various schools of thought. I also have no idea about conditions in your area so ...
