    brianmiller's Avatar
    brianmiller Guest
    Default Another lintel question, or lack thereof....
    Have you all ever seen just wood supporting stone, not lintels? They've gotta be kidding. However, no distress systems observed. 10 year old home.
    Default Re: Another lintel question, or lack thereof....
    Likely, that is Lick-n-stick, not real stone.
    brianmiller Guest
    ........but......the builder used lintels elsewhere for windows/doors, just not on the front of the house. Same stones uses all around. I'm going to write it up as missing lintels.
    Chicago
    Rick is right. Very likely a masonry veneer. The wood you see is just trim. It's hard to argue with 10 years and no signs of failure.
    Check out: https://s3.amazonaws.com/eldorado-me...nes_2-4-11.pdf
    Mike Lamb
    Inspection Connection, Inc.
    Apr 2011
    Bozeman, Montana
    The window on the left showing a wood lintel has a steel lintel above it. Just not obvious.
    Oct 2010
    Luxemburg, Wisconsin
    Quote Originally Posted by brianmiller View Post
    Are you sure the lintel is missing and not just hidden. Better to write it up as "Lintel not visible."
    Bruce Low
    Green Bay Home Inspections - Radon Tests - Rental Weatherizations | Bottom Line Home Inspection
    The Bottom Line - Through an Engineer's Eyes
    John Ring's Avatar
    John Ring Guest
    Any horizontal architectural member spanning an opening and supporting a load above IS a lintel. Though not a common practice today wood lintels were very common in old construction. When using the correct wood and properly maintained they work extremely well and last a long time.
