03-27-2013, 04:31 PM #1
Another lintel question, or lack thereof....
Have you all ever seen just wood supporting stone, not lintels? They've gotta be kidding. However, no distress systems observed. 10 year old home.
03-27-2013, 04:44 PM #2
Re: Another lintel question, or lack thereof....
Likely, that is Lick-n-stick, not real stone.
03-27-2013, 05:02 PM #3
03-27-2013, 05:34 PM #4
Rick is right. Very likely a masonry veneer. The wood you see is just trim. It's hard to argue with 10 years and no signs of failure.
Check out: https://s3.amazonaws.com/eldorado-me...nes_2-4-11.pdf
03-27-2013, 07:07 PM #5
The window on the left showing a wood lintel has a steel lintel above it. Just not obvious.
03-29-2013, 05:24 AM #6
Are you sure the lintel is missing and not just hidden. Better to write it up as "Lintel not visible."
Bruce Low
Green Bay Home Inspections - Radon Tests - Rental Weatherizations | Bottom Line Home Inspection
The Bottom Line - Through an Engineer's Eyes
03-30-2013, 09:03 AM #7
Any horizontal architectural member spanning an opening and supporting a load above IS a lintel. Though not a common practice today wood lintels were very common in old construction. When using the correct wood and properly maintained they work extremely well and last a long time.
