Results 1 to 22 of 22
    Default Swinging Door near Stairway
    This appears to be a safety hazard to me but the swinging door does open onto the landing and not over the stairs. This door leads from a theatre room. I can just someone swinging it open and knocking some off the top of the stairs coming up.
    Richard Rushing's Avatar
    Richard Rushing Guest
    Default Re: Swinging Door near Stairway
    That's not right!!
    Door should swing the other way...
    rr
    I quess its one of those BI doors, Richard.
    It swings both ways.
    Falling down the stairs is like falling up the escalator.
    Old Man Falls Up EscalatorÂ*Video
    Aug 2009
    Michigan
    I can't think of a code violation. I guess it would be the same as an exterior stairway, landing and an out swing door. Isn't that the reason for the code required landing? To allow a door to swing onto it?
    The problem with this door is that it swings from the side. Your right, more likely to wack someone than a door oposite the stairs. Still see no code violation...
    Randy Gordon, construction
    Sam Sloane's Avatar
    Sam Sloane Guest
    May not be a code violation, but is clearly a safety issue.
    Aug 2009
    Michigan
    Quote Originally Posted by Sam Sloane View Post
    I don't disagree about the safey issue... Does that door just lead to a closet? If so, then I would say not even a saftey issue.
    Quote Originally Posted by Door Guy View Post
    It leads to and from the theater room, as in kids running to get popcorn, Mom arriving with popcorn.
    I would call for a normal door there, swinging inwards. Slow the kids down.
    andy christel's Avatar
    andy christel Guest
    I agree Rick that would be a safety issue.I can see it now. Mom coming up to put laundry away and Wham O.
    Apr 2010
    Connecticut
    This is not a clear code violation as the door does not swing out over the stairs. This is an instancewhere I might verbally mention that a see through panel (window) in bi-directional doors is common in the restaurant industry.
    Stanley Chow's Avatar
    Stanley Chow Guest
    This is a code violation. The door is swinging into the path of egress and reduces the exit capacity of the stair width and landing area. Code prohibits obstructions in the clear path of egress.
    Aug 2009
    Michigan
    Quote Originally Posted by Stanley Chow View Post
    Hi Stanely, will you quote the code section please. If I and others are incorrect we would really like to know. Thanks.
    James Duffin's Avatar
    James Duffin Guest
    This is not in the NC code. What code are you getting this from?
    Healdsburg, CA
    Not all dumb conditions in the construction world are addressed by the codes. It's a safety hazard, plain & simple, but you know that.
    James Duffin Guest
    What I do know is that if I put something in a report as a repair item I best have a reason beside I think it is a good idea. As someone said above I might mention it verbally but it will never make it into the report since it really not a violation.
    You mean you can't say "this could be a safety concern" in your report? Who says you can't?
    I would suggest finding a way to report a simple hazard like this in your report. It is not a deal breaker, so why would a gang of realtors whom seem to be in charge give a crap?
    James Duffin Guest
    Because to me it is not a big problem. If I think something is a safety hazard it will be in my report. As far a Realtors being charge you must be talking about the way you do business....not me.
    That is not a code violation.
    You are possibly thinking of the building code instead of the residential code.
    Aug 2009
    Michigan
    Agreed Jerry, you must admit, this also works in reverse... not all dumb codes are easy to address in construction. No I am NOT saying codes are dumb. Just a few things in the code...
    I would say a potential reportable safety hazard.
    Oct 2010
    USA
    There is no code violation here. Jerry is right about it being a egress code violation in the building code. This comes under the residential code. I would not mention it in my report.
    Stanley Chow Guest
    You guys are correct....it's in the building code but not the residential code. Too bad cause common sense does not always prevail. I was taught in the building codes that the landing was was part of the stairs; hence an obstruction to the egress path.
