Results 1 to 9 of 9
    Aug 2009
    Oklahoma
    Default Help Identify Substance on Metal Door Frame
    Commercial building inspection. Aluminum door frame and threshold. Bottom of door frames are rusting and threshold is showing signs of deterioration. This white substance was built up in several areas. Could it be leftover ice melt? It was the consistency of wet laundry detergent. Thanks.
    Default Re: Help Identify Substance on Metal Door Frame
    Probably aluminum oxide or whatever corroding aluminum makes when the aluminum corrodes into that stuff.
    Those are most likely aluminum, not steel, so it would be corrosion, not rust ... but ... I guess "rust" is a type of "corrosion" ...
    Yes, ice melt salt will do exactly what you have in the photos.
    Is that the left over salt used for melting the ice, or is that the aluminum corrosion the salt causes? Or is that possibly both?
    Aug 2011
    If it came from the aluminum, you'll see deterioration of the aluminum. I lean toward salt. Salt doesn't get washed out from the edges of the frame as easily and since salt "attracts" moisture, there can be efflorescence along the edge of the frame over time. Aluminum oxide is usually like talc in my observations and not as coarse as detergent.
    Could also be Urea or Calcium Chloride, both of which are deicing products.
    Calcium Chloride is also used for dust control on dirt roads to keep the dust down and harden the surface.
    And Urea is also a fertilizer.
    FWIW.
    New York
    Iron oxidizes (rust).
    Aluminum oxidizes too. In the form of a dull whitish patina that covers the material. The haze then protects it from further oxidation. Same thing with silver (tarnish), brass, etc.
    When we polish these metals, the black that dirties the rag is the oxidation.
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    Quote Originally Posted by Steven Turetsky View Post
    Iron also rusts through, and disappears over time as iron oxide.
    Aluminum also corrodes through, and disappears over time as aluminum oxide.
    I've many iron items "rusted out" and many aluminum items "corroded through".
    Aug 2009
    Oklahoma
    Thank you gentlemen!
