Results 1 to 10 of 10
Thread: Stucco Problems
09-03-2015, 11:17 AM #1
Stucco Problems
Hello:
I inspected a 2002 built home with what was thought to be a hardcoat stucco exterior with architectural EPS foam trim pieces like window sills and an exterior baseboard trim piece around the entire home - but I am not 100% sure. What seems confusing is the foundation level image with double foam thickness which may indicate an EIFS with the EPS baseboard trim applied on top? Also observed was baseboard trim separating from the side of house, exposed EPS foam ends and rust bleeding through various wall surfaces and some minor wall cracking. Questions include: Do hairline cracks normally occur on EIFS walls, are exposed EPS foam ends acceptable, what would cause the separation and what would cause the rust bleeding through. Thanks!
Kevin Minto
Northern California
www.SignetHomeInspections.com
Similar Threads:Last edited by Kevin Minto; 09-04-2015 at 09:32 AM.
09-03-2015, 04:36 PM #2
Re: Stucco Problems
Questions include: Do hairline cracks occur on EIFS stucco walls
09-03-2015, 05:50 PM #3
Re: Stucco Problems
Steven hit the highlights…. I would have just said it is messed up!
09-04-2015, 08:49 AM #4
Re: Stucco Problems
Referring to Exterior Insulation Finishing System (EIFS) as opposed to a hardcoat stucco which can sometimes be difficult to differentiate between especially when a hardcoat is used in conjunction with an architectural baseboard trim as shown in several images.
What materials are you referring to?
09-04-2015, 09:51 PM #5
Re: Stucco Problems
Did a crappy job applying the foam trim.
https://www.youtube.com/watch?v=9EqY8UJ9R9E
d - - -
Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
09-04-2015, 10:04 PM #6
Re: Stucco Problems
[QUOTE=Marc M;260060]Did a crappy job applying the foam trim.
Funny thing Marc, I was actually watching that video when I received your message. Definitely spot on and I have emailed Kirk Giordano to see if he is available. Thanks!
09-06-2015, 06:08 AM #7
Re: Stucco Problems
I believe the wisest thing you should do is have an experienced Building Envelope Inspector/Moisture Analyst inspect your clients building. Such an inspector will be able to differentiate between masonry stucco, EIFS, etc. They will test the building and confirm the conditions.
This is not a job for an installer.
The materials I was referring to at the corner was nails, corner bead(s), etc.
09-09-2015, 08:06 PM #8
Re: Stucco Problems
09-10-2015, 10:22 AM #9
Re: Stucco Problems
Thanks Guys, I appreciate everyone taking the time to respond!
Kevin Minto
Signet Home Inspections, LLC
09-10-2015, 08:30 PM #10
Re: Stucco Problems
Looks like a real crappy stucco job-report what you see, and describe it as siding failure/defects, likely due to substandard workmanship/materials/methods and recommend evaluation and estimates of remedies by a stucco expert.
JP
