    Erwin, TN
    Default Stucco touching roof surface
    What is the standards for EIFS stucco finish being kept off the roof surface ?? Thanks in Advance
    Aug 2009
    rockport texas
    Default Re: Stucco touching roof surface
    At least 2"
    Sep 2009
    Arnold, MD
    doubt there is a weep screed there either
    Quote Originally Posted by biglebowski View Post
    Jeff,
    If that is barrier EIFS, the no weep screed would be required as it was (yeah, right) a "barrier" system.
    If it was a newer EIFS with a drainage plane behind it, then a weep would be needed.
    As I recall (I'm not an EIFS person), the bottom of barrier EIFS still required an accessory protecting the bottom edge - Scott P. or one of the other EIFS experts here will swat at me if I am wrong, or may confirm if I am correct ... either way - I'll duck.
    Nov 2010
    California
    That makes doing a re-roof difficult.
    Jeff,
    It either needed the plastic accessory or to be backwrapped
    Mark Parlee
    WWW.theBuildingConsultant.com
    EDI instructor, EIFS AMSV
