    Oct 2009
    houston
    Default Wrapping window question....
    Is wrapping the window with the house wrap not required when hardie siding is installed? at the exterior of that area?
    Apr 2013
    High Springs, Florida
    Default Re: Wrapping window question....
    It is required.
    www.1stproinspection.com
    Certified Master Inspector
    Like Us On Facebook
    https://www.facebook.com/1stproinspection/
    Quote Originally Posted by TcDuhon View Post
    Hardie's installation instructions are available online through their website.
    Wrapping the window, or wrapping the window framing at the window opening? Two different things.
    The window opening is wrapped over the framing, the window is flashed (usually with flexible flashing tape) to the WRB.
    Oct 2009
    houston
    OK. I thought so. I did look at the hardie website, but it seem to just talk about the above flashing and taping but not about the framing wrap (scanned over the site).
    I called it out at a framing and the builder is trying to say it isn't required at the 2nd story where hardie is getting installed.
    thanks,
    Jan 2019
    Minnesota
    As per my point of view, you should include it. It is necessary!
