Results 1 to 10 of 10
Thread: Vinyl Siding
03-31-2008, 01:01 PM #1
Vinyl Siding
Do I need to commend on the stains.
Thanks.
03-31-2008, 01:41 PM #2
Re: Vinyl Siding
It's pretty obvious Zibby, but now if any exterior wall is covered with vinyl wallpaper on the interior of the home I suspect there may be a real problem? Only destructive testing can confirm, but I’d put my client on notice.
03-31-2008, 01:58 PM #3
Re: Vinyl Siding
Yes. Vinyl siding is over wood. And the wood is rotted.
What is the best reporting Language for this type of problem?
03-31-2008, 03:17 PM #4
Re: Vinyl Siding
How do you know the wood is damaged?
03-31-2008, 03:25 PM #5
Re: Vinyl Siding
The wood is rotted at the siding base.
Looks like the siding needs to be power washed.
03-31-2008, 05:12 PM #6
Re: Vinyl Siding
The siding may need cleaning, but I wouldn't recommend power washing vinyl siding to a client. They can potentially force water up and behind the siding.
04-01-2008, 09:15 AM #7
Re: Vinyl Siding
You guys really think it's coming from the inside out?
In the picture the staining looks green. I've seen this on vinyl when a tree(s) overhang the roof, leaves build up on roof, rot and the algae runs down during rains.
04-01-2008, 10:51 AM #8
Re: Vinyl Siding
That's just blasted algae growing on the side of the house. Spray with a commercial siding cleaner and then wash off with a garden hose. End of story.
Now if the substrate is rotting along the base, it sounds like the siding is not finished properly with a "J" channel along the bottom of the siding or it is too close to the ground.
04-01-2008, 11:50 AM #9
Re: Vinyl Siding
I was considering it "mildew", but, then, "mildew" and "algae" are basically the same, right?
Is 'wood' considered a WRB? If so, then it may be allowed, but that may still be the cause.
04-01-2008, 04:44 PM #10
Re: Vinyl Siding
Scott's right.....algae. Some TSP and a stiff brush and it'll be gone.
