Results 1 to 2 of 2
    dan orourke's Avatar
    dan orourke Guest
    Default Commercial: Stucco interface with flat work
    Default Re: Commercial: Stucco interface with flat work
    Depends.
    If on frame, stucco should clear landscape (earth) by 6" and hardscape (concrete flatwork) by 4".
    If on masonry or concrete, and the stucco is less than 5/8" thick and fully adhered (as it should be), then the stucco can continue down into earth.
