Old 05-18-2007, 07:41 AM
Window flashing caps
Old 05-18-2007, 06:05 PM
Michael Thomas's Avatar
Re: Window flashing caps
The rule I remember is that flashing is required when vertical distance from the bottom of the eave to the top of the trim is more than one-quarter of the horizontal overhang of the eave. When I Google that, however, i only turn up references to Canadian requirements.
Old 05-18-2007, 06:43 PM
I'm guessing that if you look up some manufacturer's installation instructions, and if they address flashings (as most do) you will find that *they* want their windows flashed - regardless where the window it.
Because *they* don't want leaks associated with *their* windows.
Old 05-18-2007, 09:39 PM
Thom Walker's Avatar
I would suspect that window manufacturers paying warranty claims on window flashing leaks is just second to shingle manufacturers paying water damage claims.
- Paul Fix
Old 05-20-2007, 06:28 PM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Personally I'd let it go. If the wind was strong enough to get rain that far under the eaves then the homeowner will have more than flashing to worry about.
Eric Barker
Barrington, IL
Similar Threads
Jack flashing shingles at edges. Eric Shuman Roofing System: Home Inspection and Commercial Inspection 5 05-08-2007 06:31 AM
Skylight flashing new construction Eric Shuman Roofing System: Home Inspection and Commercial Inspection 1 05-03-2007 05:52 AM
Fastener type for flashing dan orourke Roofing System: Home Inspection and Commercial Inspection 10 04-19-2007 03:51 AM
Roof flashing william siegel Roofing System: Home Inspection and Commercial Inspection 2 04-18-2007 03:50 PM
Chimney Flashing Warren Alderman Attic Areas: Home Inspection and Commercial Inspection 3 04-06-2007 09:43 AM
vB.Sponsors
Ad Management by RedTyger
