LinkBack (1) Thread Tools Search this Thread
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 05-19-2007, 03:20 PM
David Banks David Banks is offline
Siding stains
Anyone familiar with these siding stains? Cause? Cedar siding.
Dave
Old 05-19-2007, 03:46 PM
Bob Stark Bob Stark is offline
Re: Siding stains
Dave,
Are those stains something that the homeowner can take care of with pressure washing? Any way to tell if the siding is actually impregnated with the stain?
What sort of camera are you using?
Old 05-19-2007, 04:45 PM
Re: Siding stains
Hi Bob, They did come off just by rubbing on them with my hand but father in law thought there was huge moisture issue behind siding.
Camera is Canon Power Shot SD600.(Elph)
Dave
Old 05-19-2007, 05:26 PM
Re: Siding stains
Hey Dave !
Upon closer look, I do notice that, moving upward from the "ground", the staining terminates rather go all the way up the wall. Moisture behind the siding, I would think, is a possible concern. Seems like a good call.
I am using the Nikon L11. I suppose all the small digitals work pretty similarly depending on features. I was just curious. Is there anything you DON'T like about the camera? I am still in the camera 'experimental' stage ! May switch to Canon..... ??
Bob
Old 05-19-2007, 06:15 PM
Re: Siding stains
Bob. Actually can not think of anything I do not like about the camera. Maybe a bit small for my clumsy ex concrete hands. But fits nicely in pocket.
I like the eye viewer for direct sunlight. Most cameras just have LCD screen and hard to see what your looking at in Bright light.
I bought a bigger memory card and extra battery. Good to go. Did almost 300 pics with one card and same battery.
Dave
  #6 (permalink)
Old 05-19-2007, 07:26 PM
Re: Siding stains
Dave, that's great! I bought the 512meg card... I can take up to about 190 hi-res pics with it. Did you buy a 1 gig card ?
Bob
  #7 (permalink)
Old 05-20-2007, 04:30 AM
Re: Siding stains
Bob. 512.
Dave
  #8 (permalink)
Old 05-20-2007, 09:49 AM
Eric Shuman Eric Shuman is offline
Re: Siding stains
Hi Dave
Without more photos it would be hard to tell but one possibility is that this staining is the result of air pollution films on the siding that are running down with increased moisture in the air or from rain. The fact that it terminates partially up the wall could be due to the overhang of the eave that prevents moisture from settling on the wall above a certain point.
Just an idea but I have seen this type of pollution staining many times before. Of course it is possible that there is moisture in the wall but I would look for other evidence to suppot that.
Hope this helps,
Eric
  #9 (permalink)
Old 05-20-2007, 10:36 AM
Scott Patterson's Avatar
Re: Siding stains
With it being ceder, it could be the resin from the wood interacting with the moisture barrier. I have seen this on homes that have felt paper as the moisture barrier. But, it does not brush off like you said you were able to do with it.
Scott Patterson
  #10 (permalink)
Old 08-04-2007, 03:03 PM
Randy Aldering Randy Aldering is offline
Re: Siding stains
Mildew stains from moisture behind the siding? What is on the other side of the wall? Is this in a cold climate?
Randy Aldering, RHI CHI
Housesmithe Home Inspection
www.housesmithe.com
LinkBacks (?)
LinkBack to this Thread: http://www.inspectionnews.net/home_inspection/building-envelope-home-inspection-commercial-inspection/1151-siding-stains.html
Posted By For Type Date
SwiftPageEmail Subject: Inspection Radio Weekly Review - Issue 5 This thread Refback 05-24-2007 02:17 PM
Similar Threads
Siding Interface with Chimney Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 3 05-03-2007 06:42 PM
Multiple siding layers dan orourke Building Envelope: Home Inspection and Commercial Inspection 3 04-25-2007 05:08 PM
Siding question Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 6 04-21-2007 11:18 AM
Stains on the interior walls? Mike Huppi Building Interior: Home Inspection and Commercial Inspection 5 04-09-2007 06:46 PM
vB.Sponsors
Ad Management by RedTyger
