Old 05-30-2007, 08:51 AM
dan orourke dan orourke is offline
Exterior steps
Home inspection
Old 05-30-2007, 02:42 PM
Re: Exterior steps
Sort of correct.
Handrails must be returned.
To the wall, guardrail, floor, or a newel post.
That handrail was not originally returned, someone tried to 'return' it and did a hack job.
Not good the way it is in the photo.
They had the right idea, but their execution of it was was off. Besides, those are "handrail brackets', not "handrail returns".
Old 05-30-2007, 04:14 PM
Re: Exterior steps
Yes. And when you do, refer to those as "handrail brackets", adding that the "handrail is required to be returned in addition to being supported by brackets" or something like that.
Old 05-30-2007, 04:16 PM
Thom Walker's Avatar
Re: Exterior steps
I'm not Jerry, but what should be done and what the builder has to do are different animals. Depending upon the location of the stairs, he MAY not have been REQUIRED to even place a handrail.
Go to a thread under Exterior systems, started on 4/16 "Docks and Decks." I asked a question from a similar scenario.
Of course you know how it should be done and that reporting what you have is the right thing to do. But if the stairs are off a deck or dock, you may not find support.
- Paul Fix
Old 05-30-2007, 04:30 PM
Re: Exterior steps
Quote:
True, BUT, if the HI does not tell the builder to correct the problem, what are the chances the builder will take it upon themselves to do so? No chance.
When working for our clients we must remember that code is only the absolute crappiest one is legally allowed to build, and HIs should be looking for/at code, not as a destination to arrive at, but as the starting place from which nothing should be worse than. Better is good.
I always had fun with builders who would try to hide behind the 'it meets code because it was signed off', even though I was showing them that the item in question did not meet code. I would then turn to my client and ask if they bought minimum housing and if their house was advertised as being minimum housing, when they said no, I would explain that code is only the absolutely crappiest the builder is legally allowed to build to, and that if their house was advertised as 'custom', 'upgraded', or, heaven forbid "LUXURY", then the builder has not standing to stand on code, even if something does meet code, because code IS NOT 'custom', 'upgraded', or 'luxury' - code is minimum housing.
Now, as you are explaining that to someone who is purchasing a $5 mil house, they kind of get red in the face and some even go into a rage ... at the builder of course, "HOW DARE YOU try to defend yourself on code ... ". The best part is, the builder has no respond he can make without digging his hole even deeper.
That also works with people who are having $250k homes built, although they cannot afford to go into a rage with the builder, they (and the builder) now know who has the upper hand (the client) when it comes to 'what was delivered versus what was promised'.
I once had a client whose builder thought they had more money than god and could do as they wanted, until they learned that god borrowed from the client's piggy bank.
Similar Threads
Raised platform -- steps needed? John C Ritter Building Interior: Home Inspection and Commercial Inspection 8 05-24-2007 04:14 PM
Interior or Exterior:Boulder Paul Kondzich Building Interior: Home Inspection and Commercial Inspection 10 05-10-2007 08:04 PM
Exterior Installation of Gas Flex Line Nick Ostrowski Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 14 04-28-2007 02:38 PM
Exterior JB Warren Alderman Electrical Systems: Home Inspection and Commercial Inspection 3 04-12-2007 05:56 PM
Staining on exterior wall near A/C Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 2 04-08-2007 03:30 PM
vB.Sponsors
Ad Management by RedTyger
