05-30-2007, 10:01 AM
crack driveway/house
05-30-2007, 10:17 AM
Re: crack driveway/house
Looks like the stone is being supported on a portion of the drive which should be a separate free-floating pour. I think the cracks have likely been created when the drive moved independently (as it should). They should not have supported the stone work on the drive but on the house.
No SE in my opinion, just fix it.
Mr. Inspector.net, Inc.
Allen, Texas 75002
05-30-2007, 02:16 PM
I agree with the no SE.
Calling for an SE on that one would be like calling for a brain surgeon to cut out an in-grown toe nail.
RR
Richard Rushing, HCRI
Duncanville, Tx.
05-30-2007, 02:38 PM
Hey, for those of us who frequently have our feet in out mouths....
05-30-2007, 03:39 PM
That concrete under the wall looks like it is still a bit green (damp). Could a repair have been made it that area recently?
05-30-2007, 04:09 PM
Yep, and 'fixing it' means cutting out the drive curb (or whatever that is) and constructing a proper footing/ledge for the masonry veneer (stone veneer is still masonry veneer).
However, what if the masonry veneer is not really masonry veneer as we typically think of it, what if that masonry veneer is fully adhered veneer, where the veneer is adhered to the wall?
In that case, the stone is not setting on the drive, but movement of the drive may have 'taken the stone with it', either through better adhesion of the mortar to the stone and the drive than to the wall, or, the drive could have 'kicked up', shearing the stone from the wall.
Did you tap on it to see if it was hollow, loose, etc.?
06-08-2007, 10:47 AM
Dan, ... No worries, I've already made repairs to it (in cyber space anyway). If it were my house, I would have done it this way, .... as shown in the redone picture. Now, knowing Jerry, ... he'll find "something" wrong with my repairs - lol. No disrespect intended, Jerry.
Robert
Roberts Home Inspection Service
06-08-2007, 11:19 AM
Interesting choice of materials for that repair.
One material does not cast a shadow while one material acts like a prism and redirects the angle of the shadow.
06-08-2007, 01:46 PM
And, like wallpaper, it has a repeating pattern.
(Good job, Robert.)
Bruce Breedlove
www.avaloninspection.com
06-08-2007, 03:49 PM
I'd like to send my wife's ass to Cyber construction so that someone could fix her-up... geeze.
Freaking flashes are whoopin my azz.
Rich
Duncanville, Tx.
06-08-2007, 04:02 PM
Here's a way to fix it and save some money. Can I be a builder now?
- Paul Fix
06-08-2007, 07:24 PM
See that downspout? Does it drain on the ground right below. If so, thats the cause. Water has undermined the footing causing settlement. Rerout the downspout, seal the crack and monitor for further movement.
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Micky mouse was at this house |
Mike Huppi |
3 |
05-30-2007 08:50 AM |
| Who's to blame for a rotten house? - The Olympian |
Brian Hannigan |
Associations, Ethics, Standards, Licensing, Legislation:Home Inspectors & Commercial Inspectors |
0 |
05-29-2007 05:31 AM |
| Crack in foundation |
Jeff Eastman |
Structural Components: Home Inspection and Commercial Inspection |
15 |
05-22-2007 01:15 PM |
| Crack in the wall |
Mike Huppi |
Building Interior: Home Inspection and Commercial Inspection |
17 |
04-18-2007 12:44 PM |
| caulk that crack says SE |
John Arnold |
6 |
04-12-2007 02:33 PM |
