Originally Posted by
Jeff Eastman
Would you recommend removing the stones or since there are weep holes, that would be sufficient?
I would tell them that, although the stones "look pretty", there is very little chance of that post inside the stones not rotting out (presuming it is a solid post as it looks to be), and that replacing the rotter out post later could be costly. Then add that it's their choice to have the post enclosed in "pretty stones now and a costly repair later", or, "do away with the pretty stones and have the plain post last a lot longer".
The choice is their, it is our job to find and advise - which you would have done.
My guess is that they will 'keep the pretty stones' and think 'it won't rot out while I own the house', and they may be correct, but ... as I often say, when they become the seller and the buyers inspector points the same thing out ... that buyer may opt for tearing the stones off and exposing the wood post, and replacing it if rotted - all BEFORE they close.
Yes, now it is the builders problem, later it will be their problem. Again, though, it is their decision. Advise them and let them decide - no matter how much you tell them about the potential for that to rot out, they will likely opt for "pretty now".
