LinkBack (2) Thread Tools Search this Thread
  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 06-05-2007, 12:59 PM
John Stephenson John Stephenson is offline
A+ for effort, but is it allowed?
Old 06-05-2007, 01:35 PM
Chip O'Brian Chip O'Brian is offline
Re: A+ for effort, but is it allowed?
Is this a new build? if so hire a new contractor. As to the flashing it appears to be a poor attempt at a diverter/kickout flashing. At any rate incorrect this would create moisture issues runnning water down the sidding.
As to the boots looks like a home style fix to me!
Old 06-12-2007, 03:45 AM
Chad Fabry's Avatar
Chad Fabry Chad Fabry is online now
That's just hokie.
Chad Fabry, Rochester, NY
StructureSmart Home Inspections, Inc.
www.structuresmart.com
Old 06-23-2007, 08:54 AM
bruce m graham III bruce m graham III is offline
Was there a kickout flashing?
Old 08-13-2007, 09:48 AM
Randy Aldering Randy Aldering is offline
No-go.
Randy Aldering, RHI CHI
Housesmithe Home Inspection
www.housesmithe.com
  #6 (permalink)
Old 08-17-2007, 05:03 PM
Dan Cullen Dan Cullen is offline
'D' for Dumb. Why worry whether or not it is 'allowed' when a little bit of thinking will tell you that it won't perform? The bottom lip of the boot will not drain and will actually collect moisture. Even if he drilled or cut a weep hole in the bottom of the boot, the flexible flashing is prone to excess motion and sealant failure. Corporate specs? Like Enron, Kerr McGee, Halliburton, etc? Your BS detector should be in the red zone.
Dan Cullen
www.domicileconsulting.com
Chicago IL
LinkBacks (?)
LinkBack to this Thread: http://www.inspectionnews.net/home_inspection/building-envelope-home-inspection-commercial-inspection/1471-effort-but-allowed.html
Posted By For Type Date
InspectionNews This thread Refback 06-26-2007 06:26 PM
acceptable, allowable to use blocks to support the fireplace? 2- 3/4" This thread Refback 06-12-2007 09:04 AM
Similar Threads
BNI groups, are they worth the effort? Joe Tribuzio Business Operations: Home Inspectors & Commercial Inspectors 9 05-30-2007 10:00 AM
vB.Sponsors
Ad Management by RedTyger
