Old 06-27-2007, 07:35 AM
RobertSmith RobertSmith is offline
Vinyl siding flashing
Old 06-27-2007, 11:05 AM
Michael Thomas's Avatar
Re: Vinyl siding flashing
"J" channel is all that's required there, the water seal is provided (hopefully) by the window 's flashing below the siding:
http://www.rd.com/images/tfhimport/2...e005img002.jpg
See for example pp 19 here:
http://www.vinylsiding.org/publicati...al_english.pdf
The kickout is a potential trouble spot, I'd be concerned about its construction - for starters, that caulk is not going to form a permanent seal - and about the detailing you can't see behind the siding at the roof/wall junction, unless that's done properly you are just funneling water into the wall. If accessible I would check the wall behind and below that junction with a Tramex or similar meter.
If you are registered there, check out this thread on the NACHI board:
kickouts - NACHI Message Board
Old 06-28-2007, 05:38 PM
Chad Fabry's Avatar
Chad Fabry Chad Fabry is offline
It's an idiotic design that will be problematic for the life of the structure.
The kick out was designed by a trained chimp. I'm sorry, that was harsh; a poorly trained chimp.
Chad Fabry, Rochester, NY
StructureSmart Home Inspections, Inc.
www.structuresmart.com
Old 06-29-2007, 05:18 PM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Flashing over windows that have a nailing flange will not need the additional flashing - provided the building paper is proper taped underneath. Also, no caulk should be present between the J-channel and the top flange - that's a very common oops.
Eric Barker
Barrington, IL
Similar Threads
Siding stains David Banks Building Envelope: Home Inspection and Commercial Inspection 9 08-04-2007 03:03 PM
Vinyl siding Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 2 06-01-2007 07:22 PM
Siding Interface with Chimney Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 3 05-03-2007 06:42 PM
Multiple siding layers dan orourke Building Envelope: Home Inspection and Commercial Inspection 3 04-25-2007 05:08 PM
Siding question Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 6 04-21-2007 11:18 AM
vB.Sponsors
Ad Management by RedTyger
