Old 06-30-2007, 10:03 AM
Jim Dull
Posts: n/a
Window Hazards
These windows are about 2 feet from the ground. They require safety glazing. Right? They are in every room of the upstairs.
Old 06-30-2007, 10:59 AM
Thom Walker's Avatar
Re: Window Hazards
No Jim. For safety glass to be required in your example, it would have to meet ALL of the following:
  • exposed area of gazing>9sq ft
  • bottom edge<18 inches
  • top edge > 36 inches above floor
  • within 36 inches horizontal of walking surface
Even when all those exist, if a minimum 1 1/2 inch high protective barrier is constructed at 34 to 38 inches above the walking surface, the safety glazing is not required.
- Paul Fix
Old 06-30-2007, 11:19 AM
Re: Window Hazards
This is the key one here in most cases.
That mean 'ONE SINGLE' pane is that large. Not the entire window opening.
Old 06-30-2007, 02:30 PM
Jim Dull
Posts: n/a
Re: Window Hazards
Thanks guys.
Old 06-30-2007, 02:55 PM
Richard Rushing's Avatar
Re: Window Hazards
Hello Jim,
For future visual reference, here are a couple of illustrations to add to your library to glance at when the need should present itself:
(see attachments)
Richard
Richard Rushing, HCRI
Duncanville, Tx.
  #6 (permalink)
Old 06-30-2007, 06:10 PM
Jim Dull
Posts: n/a
Re: Window Hazards
Thanks Richard. That is very helpful.
Similar Threads
Window seal problems! Help! rob martinez Building Envelope: Home Inspection and Commercial Inspection 11 11-04-2007 06:02 PM
B Vent Window Clearance Jim Robinson Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 9 06-16-2007 09:11 AM
Window Glazing Trim John Stephenson Building Envelope: Home Inspection and Commercial Inspection 3 06-01-2007 12:29 PM
outside my window John Arnold Tools and Equipment 6 05-07-2007 06:19 AM
Leaking window william siegel Building Envelope: Home Inspection and Commercial Inspection 5 04-10-2007 09:02 PM
vB.Sponsors
Ad Management by RedTyger
