Results 1 to 14 of 14
Thread: Glass panel garage door
06-26-2010, 02:08 PM #1
I inspected a 1995 house today that was the model for development at one time. There is a glass panel door from garage to house. Is this allowed?
06-26-2010, 03:41 PM #2
Re: Glass panel garage door
I can't say for sure on 1995, but I think not.
2006 IRC
R309.1 Opening protection.Openings from a private garage
directly into a room used for sleeping purposes shall not be permitted.
Other openings between the garage and residence shall
be equipped with solid wood doors not less than 13/8 inches (35
mm) in thickness, solid or honeycomb core steel doors not less
than 13/8 inches (35 mm) thick, or 20-minute fire-rated doors.
06-26-2010, 04:22 PM #3
Thanks Rick!!!
06-26-2010, 09:41 PM #4
There ARE 20/45/60/90-minute fire-rated glass doors.
Check the door/jamb/frame for a rating plate.
06-27-2010, 01:20 PM #5
While "There ARE" those fire rated doors, it is HIGHLY UNLIKELY to find one in a residence, much less one with a glass in it - yes, check the jamb/frame/door edge for a rating plate, but it is highly unlikely that one will find the door to be a fire rated door in a residence.
06-27-2010, 03:26 PM #6
I think it is MORE than likely, especially since the home was part of a development, occupied by the builder, as a model home/office for the development. More esp. in former UBC territory circa 1995.
Few AHJs would overlook a 20-minute rating requirement for door separating residence and attached garage, especially one gaining occupancy of a public nature, early on in the development as a builder's model/office.
06-27-2010, 03:55 PM #7
06-27-2010, 04:15 PM #8
If its got glass it "ain't" one of the "other options".
06-27-2010, 06:01 PM #9
DUH!
And it its got glass it "ain't" necessarily a fire rated door option either.
Jeez, Watson, get off your high rocking horse and think, man, think. Just because "If its got glass it "ain't" one of the "other options"." DOES NOT MEAN it is "the other option" (i.e., a fire rated door), it PROBABLY means it "ain't" any of the allowable options.
Jeez.
06-27-2010, 06:34 PM #10
06-27-2010, 06:41 PM #11
I've seen where a door with glass replaced the solid door after the final inspection was done.
08-05-2010, 09:05 PM #12
Hey there,
Other than wire meshed glazing and ceramic glazing, does anyone know if other types of glazing are permitted in man doors....such as tempered glass?
Couldn't locate any labels on the unit I looked at today.
Appreciate any feedback.
R
08-06-2010, 04:28 PM #13
No label = not a fire rated door = not allowed unless it meets what Rick posted:
- 2006 IRC
- - R309.1 Opening protection. Openings from a private garage directly into a room used for sleeping purposes shall not be permitted. Other openings between the garage and residence shall be equipped with solid wood doors not less than 13/8 inches (35 mm) in thickness, solid or honeycomb core steel doors not less than 13/8 inches (35 mm) thick, or 20-minute fire-rated doors.
08-06-2010, 06:10 PM #14
