Old 07-14-2007, 05:58 PM
dan orourke dan orourke is offline
Window question
Old 07-14-2007, 06:49 PM
Re: Window question
Dan,
No photo.
If I am imagining them correctly, they are for drainage. DO NOT seal them.
Old 07-15-2007, 08:59 AM
Re: Window question
Those ARE NOT as I imagined them.
Those (to the best I can tell) should be sealed - they are within the weather-resisting area of the window. Any water which gets in there will leak down.
Now, *IF* (a big IF) those leak down to a channel which drains out, then you would also see the holes I was imagining - drain holes on/to the exterior.
Old 07-15-2007, 09:17 AM
Jim Robinson's Avatar
Jim Robinson Jim Robinson is online now
Re: Window question
Weep holes. They should correspond to another set of holes on the lower outside part of the window frame. Don't seal them.
Old 07-15-2007, 09:25 AM
Scott Patterson's Avatar
Re: Window question
Yes, those are weep holes. That window has an interior pan that directs the water to a set of exterior drain holes. Hopefully the exterior drain holes have not been clogged up with stucco, etc.
Scott Patterson
  #6 (permalink)
Old 07-15-2007, 11:36 AM
David Banks David Banks is offline
Re: Window question
If those are weep holes as Jim and Scott say(No reason to doubt) you would think they would function better if they were down lower to the frame where the water would collect.
Dave
  #7 (permalink)
Old 07-17-2007, 10:20 AM
Re: Window question
I've never seen windows designed to get water 'inside' like that and then drain it back out, except for sliders (which, of course, do this).
Learned something new too.
  #8 (permalink)
Old 07-17-2007, 10:42 AM
BARRY ADAIR's Avatar
BARRY ADAIR BARRY ADAIR is offline
Re: Window question
The better end windows put their name on the lock mechanism. It is then very easy to go to their site and view tech data and schematics.
A number of vinyl units have this type of drainage or removable sill track with weeps that can be cleaned out as necessary.
Residential-Commercial-Construction-EIFS-Infrared Thermography
Home inspection
Similar Threads
Window question Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 5 07-09-2007 04:33 PM
Window Hazards Jim Dull Building Envelope: Home Inspection and Commercial Inspection 5 06-30-2007 06:10 PM
outside my window John Arnold Tools and Equipment 6 05-07-2007 06:19 AM
Window safety locks Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 5 05-03-2007 10:55 AM
Leaking window william siegel Building Envelope: Home Inspection and Commercial Inspection 5 04-10-2007 09:02 PM
vB.Sponsors
Ad Management by RedTyger
