Originally Posted by
dan orourke
60 year old home. Homeowner installed new vinyl siding and new double pane window.
Do you agree that the casement trim should overlap the windows, seems like big time water leak to me?
Also, no metal window flashing caps needed, correct? What they did is okay?
The trim should be on top of the window.
No cap is needed the "J" channel keep the water from getting in. Look at the file that Jerry attached it should have it all in the guidelines. If the Vinyl Siding Institute's site is up, take a look at it. It has been down for a couple of days, I needed to look something up on Tuesday and it was down then.
