Old 09-18-2007, 02:49 PM
bad install?
first pic - siding installed tight against the porch
second pic - no flashing, wood to masonry contact will wick water
All is wrong? Anything else?
Old 09-18-2007, 04:17 PM
Rick Hurst's Avatar
Re: bad install?
Matt,
You seem to be answering your own questions, don't you think?
Old 09-18-2007, 04:28 PM
Brandon Whitmore Brandon Whitmore is offline
Re: bad install?
Matt-
It sounds like you already know all this and just want another opinion-- here's mine. Hardi(e) Plank is supposed to have a min. 2" vertical clearance between the siding and concrete/ hardscapes (per installation instructions). Flashing is required where dissimilar siding materials meet (IRC '03)-- I do not see any flashing or anything that I would consider a flashing. Plus the horizontal trim board is problematic and will hold water. I would hammer on both those issues.
Brandon
Old 09-18-2007, 04:34 PM
Re: bad install?
Quote:
Originally Posted by Brandon Whitmore View Post
Matt-
Brandon
Thanks... yep, just looking for some confirmation of what I know
Old 09-18-2007, 05:06 PM
Don Emerson Don Emerson is offline
Re: bad install?
Matt-
Brandon
Anybody out there got a picture of a 2" vertical clearance as per HardiPlank instructions? I am having a hard time picturing what that would look like.
  #6 (permalink)
Old 09-18-2007, 05:19 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is online now
Re: bad install?
Don,
No picture but
The vertical is measured from the hard scape to the siding.
Just like the clearance from a slab to the siding ,should have a space between floor and
siding.
Billy J. Stephens HI Service
  #7 (permalink)
Old 09-18-2007, 06:38 PM
Re: bad install?
That looks like 'hardboard' siding.
'Hardboard' siding requires 25 miles clearance from the house (or however far away the local solid waste dump/landfill is located).
  #8 (permalink)
Old 09-18-2007, 07:26 PM
Re: bad install?
Not exactly a fan of HardiPlank- I guess. What don't you like about it?
  #9 (permalink)
Old 09-18-2007, 07:32 PM
Re: bad install?
Quote:
Don,
NOT "Hardieplank", "hardboard" - think LP, Masonite, etc.
  #10 (permalink)
Old 09-18-2007, 08:19 PM
Jon Randolph Jon Randolph is offline
Re: bad install?
I'm with Jerry, that appears to be engineered wood. Hardi-plank is a cementuous type of siding. We all know the problems that Louisianna Pacific has had with their lap siding. I always comment about the importance of paint, caulk, etc. with engineered wood, wether I see iddues or not. If I see the LP in the knot of the panel on homes I make sure that the client knows about the issues (lawsuit) with that too.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
  #11 (permalink)
Old 09-18-2007, 08:59 PM
Re: bad install?
It's cement... Hardi/Hardie - Plank - The picture is a bit fuzzy which makes it look more textured and like LP 'crapola' - I gave it the 'knuckle thump' as I call it to be sure.... There's no mistaking the cement sound vs. wood/pulp/glue/etc
  #12 (permalink)
Old 09-18-2007, 11:44 PM
Re: bad install?
Quote:
Don,
That grain pattern is very common for Hardi(e) plank around here. I can't say I have seen that exact grain pattern in these parts in a hardboard material.
  #13 (permalink)
Old 09-19-2007, 05:48 AM
Chad Fabry's Avatar
Chad Fabry Chad Fabry is offline
Re: bad install?
If it is Hardi Plank, it's "Select Cedar Mill".
All of the fiber cement products look so similar that it's hard to tell them apart even if the samples are side by side.
Cem Plank and Certainteed both have grain patterns that would blend perfectly with the one illustrated.
Chad Fabry, Rochester, NY
StructureSmart Home Inspections, Inc.
www.structuresmart.com
Last edited by Chad Fabry : 09-19-2007 at 06:11 AM. Reason: gave/have- both useful words, but not interchangeable
  #14 (permalink)
Old 09-19-2007, 06:01 AM
Re: bad install?
Quote:
In other words, don't refer to it as "Hardieplank" to your clients or in your reports, but simply as "cement board siding" ... or some other appropriate generic "name type" of siding. Like what I did when I thought it was Masonite or LP, I referred to it as "hardboard" ... least you call it Hardieplank and, when your client goes to replace some, they find a less expensive product was installed, then expect YOU to replace ALL of the 'cement board siding' with Hardieplank cement board siding, because, after all, THAT IS WHAT YOU SAID IT WAS.
  #15 (permalink)
Old 09-19-2007, 08:22 PM
Re: bad install?
Don,
Oops, someone wasn't paying attention. I'll look closer next time. BTW, I agree with you about where Masonite and LP siding belongs. Used to call on a couple of their manufacturing plants many moons ago. Wasn't impressed then, either.
Similar Threads
Trained Chimpanzees Install Flue Pipe Nick Ostrowski Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 04-05-2007 07:45 PM
vB.Sponsors
Ad Management by RedTyger
