Old 11-06-2007, 06:11 AM
Clay White Clay White is offline
Deck house flashing interface
Old 11-06-2007, 10:32 AM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Re: Deck house flashing interface
Clay,
Perhaps the flashing is underneath and lapped over the ledger board. When the flashing is not visible, often because it was never installed, it's fair to write that you did not see any flashing and question its existence.
Eric Barker
Barrington, IL
Old 11-06-2007, 05:43 PM
Darren Miller's Avatar
Darren Miller Darren Miller is offline
Here's my macro for flashing;
[0007NoFlash]As best as I can tell, the flashing is missing between deck and house. Flashing is meant to protect wood from moisture damage/deterioration. I am unable to determine if damage is currently present. I do recommend you contact a qualified carpenter to obtain accurate cost estimate to install the proper flashing. When flashing is being installed, it can then be determine if moisture or other damage does exist.
Darren
New Jersey Home Inspection - About the House!
Similar Threads
Flashing details for deck/balcony Clay E White Exterior Systems: Home Inspection and Commercial Inspection 2 09-25-2007 02:56 PM
Electrical conduits out of house/deck Clay E White Electrical Systems: Home Inspection and Commercial Inspection 5 09-24-2007 08:07 PM
Rafter interface with doubled-up 2xs Jeff Eastman Attic Areas: Home Inspection and Commercial Inspection 0 09-07-2007 12:13 PM
beam interface with shingles John Stephenson Roofing System: Home Inspection and Commercial Inspection 13 06-22-2007 01:38 AM
Siding Interface with Chimney Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 3 05-03-2007 05:42 PM
vB.Sponsors
Ad Management by RedTyger
