Old 11-15-2007, 12:23 PM
Scott Lynch Scott Lynch is offline
Weep holes over lintels
Old 11-15-2007, 05:21 PM
imported_John Smith imported_John Smith is offline
Re: Weep holes over lintels
Scott, the Brick Industry Association shows details about weeps and lintels.
See link below:
http://www.bia.org/bia/technotes/TN7.pdf
Old 11-16-2007, 04:20 PM
Bruce Lunsford
Posts: n/a
The short answer is - yes. Flashing and weeps are required over lintels, although it is VERY often not enforced.
As to the arch, I would not make an issue out of that. It is directly under a soffit so where is the water going to come from? Further, I'm not sure weeps would even function there at all anyway. IMHO it is a non issue.
Old 12-02-2007, 08:22 PM
Brian Hoagland Brian Hoagland is offline
Choose your battles, don't choose this as one. Technially the answer is yes/practiaclly the answer is NO! No sense in making enemy of the trades when it has no significant effect on the structure or inhabitants.
Old 12-03-2007, 06:51 PM
Dave Hahn Dave Hahn is offline
So WE should 'choose' what our client's get to know ???
If you know something is a defect, report it....inform them. But also inform them of the implications so they can be advised as to the significance and decide what THEY want to do (consult with a mason?).
I tell clients when weep holes are absence and, in so many words, I also tell them of the complications of trying to do something about it after the fact (do we know if the drainage plane is actually there, will the guy with the drill puncture the drainage plane if it is there, etc.).
Similar Threads
Weep holes, improper spacing Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 1 10-28-2007 11:04 AM
Window Weep holes RobertSmith Building Envelope: Home Inspection and Commercial Inspection 11 10-18-2007 06:07 PM
Weep holes Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 2 08-19-2007 05:49 PM
No Weeps Holes Erol Kartal Exterior Systems: Home Inspection and Commercial Inspection 19 08-16-2007 12:14 PM
Weep Holes Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 13 05-30-2007 05:23 PM
vB.Sponsors
Ad Management by RedTyger
