Old 12-03-2007, 03:10 PM
dan orourke dan orourke is offline
what do you call
Old 12-03-2007, 03:16 PM
Lee Nettnin's Avatar
Lee Nettnin Lee Nettnin is offline
Re: what do you call
I call it part of the fascia
Old 12-03-2007, 03:34 PM
Scott Patterson's Avatar
Quote:
Originally Posted by dan orourke View Post
the triangular section under the rake board end?
Box cornice
Scott Patterson
Old 12-03-2007, 03:40 PM
John Goad John Goad is offline
Framers in this area call it a "bird box", but box cornice sounds better on a report, unless I guess, your client is a framer from this area
Clarksville Home Inspection
JW Goad
Old 12-03-2007, 08:11 PM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
"bird box" is the term I learned when I was building houses in GA. That may be a regional term.
Bruce Breedlove
www.avaloninspection.com
  #6 (permalink)
Old 12-03-2007, 09:13 PM
Kevin Barre Kevin Barre is offline
It's "bird box" here also...but I learned that from framers...
I think "boxed end of soffitt" or "enclosed soffitt end" would work for most folks.
  #7 (permalink)
Old 12-04-2007, 07:46 AM
It is also called a "Corner return".
This website might help with some terms.
Building Construction & Finishing
Most of this information comes from a book called "Modern Carpentry" by Willis H. Wagner & Howard Bud Smith, 2003. ISBN # 1-59070-202-6 Publisher is The Goodheart=Wilcox Company.
It is a book that I use all of the time when it comes to questions about light construction.
Scott Patterson
  #8 (permalink)
Old 12-09-2007, 06:48 AM
Lloyd Woods Lloyd Woods is offline
I call it part of the gable trim
  #9 (permalink)
Old 12-09-2007, 03:40 PM
Brian Hoagland Brian Hoagland is offline
Quote:
I'm with you, I think every body else is correct with regarding the framing underneath as to the actual construction terms but the exterior facing is a part of the fascia. Besides, most laymen can get a grip on fascia but lose the ability to understand these other terms. Now if you need to refer to the structural wood elements behind the one by, it might be a good idea to go with some of those terms as applicable in your area.
  #10 (permalink)
Old 12-09-2007, 03:43 PM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Rake return.
Eric Barker
Barrington, IL
  #11 (permalink)
Old 12-09-2007, 06:01 PM
Rick Hurst's Avatar
In layman terms, its the end corner of the roof.
  #12 (permalink)
Old 12-09-2007, 08:34 PM
Nolan Kienitz's Avatar
Nolan Kienitz Nolan Kienitz is offline
Quote:
To get fancy: ... Northwest or Southeast ... end corner of the roof
Cheers - Nolan E. Kienitz, HCRI, PMP
ICC Certified Residential Plumbing Inspector (P-1)
www.NolansInspections.com
  #13 (permalink)
Old 12-10-2007, 10:21 AM
Richard Rushing's Avatar
Cornice return.
Rich
Richard Rushing, HCRI
Duncanville, Tx.
  #14 (permalink)
Old 12-10-2007, 11:16 AM
brian schmitt brian schmitt is offline
we old timers call that a "pork chop".
  #15 (permalink)
Old 12-10-2007, 02:42 PM
Ed Voytovich Ed Voytovich is offline
On older houses where the return is three dimensional, and where real carpentry was required, we refer to this detail formally in Central New York as a gable end return. Informally, it's a pigeon walk.
For this miserable, etiolated, two dimensional detail in modern construction, the term "pork chop" seems just right.
  #16 (permalink)
Old 12-10-2007, 04:28 PM
I start writing pork chop and people will really wonder what I used to do.
Eric Barker
Barrington, IL
  #17 (permalink)
Old 12-10-2007, 07:47 PM
Or what you eat...
Duncanville, Tx.
Similar Threads
what to call Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 5 11-19-2007 07:13 PM
Brain dump, what do you call dan orourke Electrical Systems: Home Inspection and Commercial Inspection 5 11-07-2007 10:29 AM
Waterbed Heater Close Call Bruce Breedlove InspectionBlues: Home Inspectors & Commercial Inspectors 0 09-29-2007 09:17 PM
The Dreaded Complaint Call Bruce Breedlove InspectionBlues: Home Inspectors & Commercial Inspectors 13 08-26-2007 09:19 PM
Call Kurtis: Home Inspection Nightmare - CBS 13 Brian Hannigan Inspection News From Around The Net 5 06-05-2007 09:18 PM
vB.Sponsors
Ad Management by RedTyger
