12-03-2007, 03:10 PM
what do you call
12-03-2007, 03:16 PM
Re: what do you call
I call it part of the fascia
12-03-2007, 03:34 PM
Originally Posted by dan orourke
the triangular section under the rake board end?
Box cornice
12-03-2007, 03:40 PM
Framers in this area call it a "bird box", but box cornice sounds better on a report, unless I guess, your client is a framer from this area
12-03-2007, 08:11 PM
"bird box" is the term I learned when I was building houses in GA. That may be a regional term.
Bruce Breedlove
www.avaloninspection.com
12-03-2007, 09:13 PM
It's "bird box" here also...but I learned that from framers...
I think "boxed end of soffitt" or "enclosed soffitt end" would work for most folks.
12-04-2007, 07:46 AM
It is also called a "Corner return".
This website might help with some terms.
Building Construction & Finishing
Most of this information comes from a book called "Modern Carpentry" by Willis H. Wagner & Howard Bud Smith, 2003. ISBN # 1-59070-202-6 Publisher is The Goodheart=Wilcox Company.
It is a book that I use all of the time when it comes to questions about light construction.
12-09-2007, 06:48 AM
I call it part of the gable trim
12-09-2007, 03:40 PM
I'm with you, I think every body else is correct with regarding the framing underneath as to the actual construction terms but the exterior facing is a part of the fascia. Besides, most laymen can get a grip on fascia but lose the ability to understand these other terms. Now if you need to refer to the structural wood elements behind the one by, it might be a good idea to go with some of those terms as applicable in your area.
12-09-2007, 03:43 PM
Rake return.
Eric Barker
Barrington, IL
12-09-2007, 06:01 PM
In layman terms, its the end corner of the roof.
12-09-2007, 08:34 PM
To get fancy: ... Northwest or Southeast ... end corner of the roof
Cheers - Nolan E. Kienitz, HCRI, PMP
ICC Certified Residential Plumbing Inspector (P-1)
www.NolansInspections.com
12-10-2007, 10:21 AM
Cornice return.
Rich
Richard Rushing, HCRI
Duncanville, Tx.
12-10-2007, 11:16 AM
we old timers call that a "pork chop".
12-10-2007, 02:42 PM
On older houses where the return is three dimensional, and where real carpentry was required, we refer to this detail formally in Central New York as a gable end return. Informally, it's a pigeon walk.
For this miserable, etiolated, two dimensional detail in modern construction, the term "pork chop" seems just right.
12-10-2007, 04:28 PM
I start writing pork chop and people will really wonder what I used to do.
Eric Barker
Barrington, IL
12-10-2007, 07:47 PM
Or what you eat...
Duncanville, Tx.
| Thread Tools |
Search this Thread |
