Old 12-03-2007, 03:13 PM
dan orourke dan orourke is offline
Driveway/garage slab
Old 12-03-2007, 03:40 PM
Scott Patterson's Avatar
Re: Driveway/garage slab
Quote:
Originally Posted by dan orourke View Post
The driveway is about one inch higher from the garage slab. I'm thinking that water can pond then try to enter the interior of the garage? Or do you think I'm off base and not bother to write this up?
It is also a trip hazard. It looks like water has already entered into the garage. I would say that this something to note, or you might be getting a call when the monsoon season arrives.
Scott Patterson
Old 12-03-2007, 03:52 PM
Ditto
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 12-03-2007, 06:31 PM
Not only 'ditto' to Scott's stuff, but adding 'something lifted that section' (or the house settled that much).
Are you in a freeze area? Or could it just have been large tree roots?
Old 12-03-2007, 07:56 PM
Kevin Barre Kevin Barre is offline
It's hard to tell from the photo, but it appears that the door casing is cut on an angle, indicating that there is a pronounced slope to the outer edge of the garage slab to drain water away. If so, water entry into the garage may not be a problem. However, it is still a valid question why the drive is higher than the garage floor. Maybe sloppy work...maybe uplift from some source affected the drive.
Home inspection
Similar Threads
Strange Driveway Detail imported_John Smith Exterior Systems: Home Inspection and Commercial Inspection 5 09-08-2007 08:03 AM
Slab question Paul Tooley Structural Components: Home Inspection and Commercial Inspection 4 07-24-2007 08:27 PM
Cracks in garage slab dan orourke Building Interior: Home Inspection and Commercial Inspection 4 06-24-2007 01:14 AM
crack driveway/house dan orourke Building Envelope: Home Inspection and Commercial Inspection 11 06-08-2007 07:24 PM
Driveway dan orourke Building Envelope: Home Inspection and Commercial Inspection 6 06-01-2007 09:13 PM
vB.Sponsors
Ad Management by RedTyger
