Old 12-10-2007, 04:45 PM
Glazing bead
Old 12-10-2007, 05:06 PM
Re: Glazing bead
Quote:
Originally Posted by Jeff Eastman View Post
The glazing bead is to hold the window pane in place
Not those vinyl or aluminum ones, they are just decorative. The glazing is held in place by the sealant.
Old 12-10-2007, 05:58 PM
Rick Hurst's Avatar
Re: Glazing bead
That plastic trim in your picture looks like its been beat to hell with hail.
Those chipped areas as is present on the side is a giveaway. Always a clue to check out the roof really well.
As JP said, there should be sealant around the glass panel which would keep the moisture out.
Looks like the window has a lost thermal seal anyway, so it needs to be replaced.
Similar Threads
Code question - safety glazing Eric Shuman Building Interior: Home Inspection and Commercial Inspection 36 06-20-2008 03:47 PM
Window glazing trim dan orourke Building Envelope: Home Inspection and Commercial Inspection 8 10-19-2007 06:17 PM
Glazing bead question Clay E White Building Envelope: Home Inspection and Commercial Inspection 2 08-04-2007 08:06 PM
Safety Glazing Jeff Gainey Building Interior: Home Inspection and Commercial Inspection 11 07-23-2007 05:53 PM
Window Glazing Trim John Stephenson Building Envelope: Home Inspection and Commercial Inspection 3 06-01-2007 12:29 PM
vB.Sponsors
Ad Management by RedTyger
