Old 12-11-2007, 10:06 PM
Rick Maday Rick Maday is offline
What do you call this?
Rope, string, wick? Why is it there?
Thanks,
Rick
Old 12-11-2007, 10:18 PM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Re: What do you call this?
I call it a weep hole.
Bruce Breedlove
www.avaloninspection.com
Old 12-11-2007, 10:44 PM
Why would there be rope in there and why so high? The others were open and just above the foundation.
Old 12-12-2007, 04:28 AM
Alton Darty Alton Darty is offline
Is that a line of flashing in the morter joint at the base of this course?
Old 12-12-2007, 05:47 AM
Aaron Miller Aaron Miller is offline
Senior Member
Rick:
It is, as Bruce pointed out, a weep wick. The plastic below this course of bricks is the flashing for the brick ledge.
Aaron
  #6 (permalink)
Old 12-12-2007, 07:48 AM
Dom D'Agostino Dom D'Agostino is offline
From the Brick Industry Association:
Quote:
What is the best weep system?
Weep systems in use include wicks, oiled rods, weep tubes, open head joints, and vents. BIA does not advocate one type of weep system over another. Wicks should be spaced at 16" o.c. with the remainder of the weep systems spaced at 12" o.c. Rope wicks can be made from cotton sash cord. Drainage materials used at the bottom of the cavity are most effective for open type of weep holes like open head joints, weep tubes, etc., however it could be used with rope wicks.
It is important to maintain a clean, open cavity for weep holes to function properly. If mortar droppings are anticipated, then it is best to detail a drainage material that will catch any mortar like pea gravel or mesh.
  #7 (permalink)
Old 12-12-2007, 08:14 AM
This ( MORTAR NET ) is a new product I've been seeing use recently. Of course, though, it has always been installed upside down and first and the masons have to remove it and install it right side up - does not work upside down.
  #8 (permalink)
Old 12-12-2007, 11:42 AM
Matthew Barnicle Matthew Barnicle is offline
One reason for a wick type weep hole is the weep wick is designed to wick up moisture from the cavity and expose it to the exterior atmosphere where it can more easily evaporate.
  #9 (permalink)
Old 12-12-2007, 04:02 PM
Donald Merritt Donald Merritt is offline
Old masons used sections of rope where the weep holes go in the brickwork. After they have laid several courses of brickwork, these sections of rope were pulled out and you had a weep hole. Now they just leave out the mortar between the ends of the brick batts. ps. the rope will not come out after the mortar has set. Also these sections of rope are too small for a proper weep hole.
Don Merritt
Germantown, Tennessee
Similar Threads
what do you call dan orourke Building Envelope: Home Inspection and Commercial Inspection 16 12-10-2007 07:47 PM
Hot/Cold reversed - do you call it? Matt Fellman Plumbing System: Home Inspection and Commercial Inspection 14 12-07-2007 05:20 PM
what to call Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 5 11-19-2007 07:13 PM
Brain dump, what do you call dan orourke Electrical Systems: Home Inspection and Commercial Inspection 5 11-07-2007 10:29 AM
The Dreaded Complaint Call Bruce Breedlove InspectionBlues: Home Inspectors & Commercial Inspectors 13 08-26-2007 09:19 PM
vB.Sponsors
Ad Management by RedTyger
