Old 12-23-2007, 10:56 AM
Wendell Swedberg Wendell Swedberg is offline
Normal Checking on wood siding?
Old 12-23-2007, 11:15 AM
Scott Patterson's Avatar
Re: Normal Checking on wood siding?
Quote:
Originally Posted by Wendell Swedberg View Post
Builder insists this is normal checking on the wood siding.
I feel this "checking" will allow water entry behind the siding.
Would you folks write siding like this as a repair item?
First off wood siding is not a barrier type siding. This is the reason that it should have a moisture barrier behind it. So the splitting or checking would really not make that much of a difference so far as water is concerned.
It look like a mill stamp on the front of that piece of wood, that in itself would be a red flag that the builder could care less about the quality of his product.
It also looks like the siding might have been nailed improperly as several corners are starting to bow out.
Scott Patterson
Old 12-23-2007, 07:37 PM
wayne soper's Avatar
The checking is normal but the use of the checked section at time of install is poor workmanship. The 2 foot checked end should have been trimmed off prior to install. A good carpenter would be able to tell that it would check in the future even though it may have looked fair at time of install. What Scott said was a stamp appears to me to be a burn mark from the thickness planer where the piece stopped for a second or two before moving again. That would also be an indication of checking as the checked section would compress as it went through the blade and expand again as it came out catching on the planer housing causing the board to jamb causing the burn mark.
Simple repair. Replace checked section. And refasten the areas where joints are starting to open. Unpainted wood will be affected more by UV and weathering. Present owner may have insisted on natural finish which would clear the builder to a certain extent.
Old 12-23-2007, 08:16 PM
Matt Fellman Matt Fellman is online now
If your profile didn't say you from Phoenix I'd swear that came off the south side of my own house... same stuff... same condition.
I see a lot of that around my area, mostly from the 70s/80s when wood started to become scarce and the quality went down.
I have a standard comment where I identify the area and then state that normal maintenance for this type of siding includes periodicly replacing or sealing any split boards and keeping all materials well painted to prevent damage.
It's one of those where I feel caught in a spot between my SOP's and a siding cotractor... SOP's say to evaluate to determine if the system is performing its intended function, contractor that comes behind me says it's all trashed, needs to be replaced and your children are going to die of mold poisoning if they sleep another night in the house.
Edit - just caught that this was a new house. That's too bad it's doing that already... I'd think the split boards should be replaced. Wow, that sun is hot down there in Phoenix isn't it? Maybe Al Gore is right
Old 12-24-2007, 08:02 AM
Quote:
Originally Posted by Matt Fellman View Post
It's one of those where I feel caught in a spot between my SOP's and a siding cotractor... SOP's say to evaluate to determine if the system is performing its intended function, ...
At a minimum ...
SOP are like 'code', they are all 'do this MINIMUM', but neither says to 'stop there'.
Quote:
... contractor that comes behind me says it's all trashed, needs to be replaced ...
Nothing in any SOP prevents you from saying it should be repaired/replaced.
Quote:
.... and your children are going to die of mold poisoning if they sleep another night in the house.
Yeah, well, the contractor's got to find a way to make a living too ...
Similar Threads
Normal "Checking" RobertSmith Building Envelope: Home Inspection and Commercial Inspection 5 10-17-2007 09:16 PM
Checking if vinyl siding is properly installed. M Kelekci Building Envelope: Home Inspection and Commercial Inspection 6 07-30-2007 11:17 AM
Wood siding trim caulked M Kelekci Building Envelope: Home Inspection and Commercial Inspection 0 07-22-2007 08:10 PM
Checking out E70 Thom Walker Associations, Ethics, Standards, Licensing, Legislation:Home Inspectors & Commercial Inspectors 30 06-18-2007 12:07 PM
Wood Structural Panel Sheathing or Siding Used to Resist Combined Shear & Uplift Brian Hannigan Building Envelope: Home Inspection and Commercial Inspection 0 05-23-2007 01:16 PM
vB.Sponsors
Ad Management by RedTyger
