Old 04-08-2008, 07:40 PM
Rick Hurst's Avatar
Brick Mortar?
Does anyone have a reference about why brick mortar should not be as such?
I told my client the brick mason needed to be in a good 12-step program.
The client told me that this was a 1800. upgrade.
Home inspection
Old 04-08-2008, 07:42 PM
David Banks David Banks is online now
Re: Brick Mortar?
Looks like amateur/homeowner work.
Dave
Old 04-08-2008, 07:44 PM
Jim Luttrall Jim Luttrall is online now
Re: Brick Mortar?
Yep, people actually pay extra for that
Looks like a Forrest Gump job to me.
Did you try the BIA manual?
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 04-08-2008, 07:48 PM
Rick Hurst's Avatar
Re: Brick Mortar?
Its a Brand new 500K home.
Old 04-08-2008, 08:02 PM
Bob Harper's Avatar
Bob Harper Bob Harper is online now
Re: Brick Mortar?
It looks like they are trying to replicate old interior wythe walls such as you would see in an old city where they built a bar or restaurant in the shell of a building leaving the interior brick exposed. totally unsuitable for exterior application. Yes, BIA technical notes one of many sources. Ask them to explain how it is to keep out water without struck joints? BTW, are there weep holes? I didn't see any.
Bob
  #6 (permalink)
Old 04-08-2008, 08:03 PM
Re: Brick Mortar?
Rick, I skimmed through the BIA web site and found nothing, might be somthing there, but not that I found.
Allen, Texas 75002
  #7 (permalink)
Old 04-09-2008, 06:26 AM
Re: Brick Mortar?
ACI 530.
All solid masonry units (brick is a masonry unit) are required to have full head and bed mortar.
All hollow masonry units are required to have head and bed mortar at least equal to the face shell thickness.
Hollow brick, of course, starts at the faces of the brick (outside face and inside face) and goes toward the center of the brick.
Regarding the non-tooled, non-struck off mortar, there is no requirement for that. Non-struck off mortar gives a look some desire (and the least weather resistant joint). Struck off mortar gives a different look, but still not a weather resistant joint. Tooled mortar gives the best weather resistant joint as the mortar is allowed to harden to "thumbprint hard" and is then tooled, i.e., compressed, into the joint.
The photo shows mortar joints which are not fully bedded, not even for the face shell thickness - and that's a no-no.
  #8 (permalink)
Old 04-09-2008, 07:17 AM
Nick Ostrowski Nick Ostrowski is offline
Re: Brick Mortar?
"Unprofessional and improper installation of mortar between bricks on exterior walls - multiple unsealed joints and gaps noted which will allow water, insect, and rodent infiltration - have serviced by a professional stone mason and all repairs/replacements made as needed"
  #9 (permalink)
Old 04-09-2008, 07:40 AM
Re: Brick Mortar?
There are some very expensive homes around here like that. People do actually pay extra, it's amazing. However, they didn't execute the technique well enough to allow it to pass.
Markus Keller
  #10 (permalink)
Old 04-09-2008, 02:29 PM
Steve Lowery Steve Lowery is online now
Re: Brick Mortar?
The white smeary appearance puts me in mind of that "mortar repair" stuff
that comes in 14 oz. caulking tubes. Squeeze it out, strike it off w/a putty
knife and call it repointed.
Similar Threads
Brick Veneer Mortar Joint Width Standard Aaron Miller Building Envelope: Home Inspection and Commercial Inspection 11 03-07-2008 12:00 PM
Vinyl over brick Richard Roshak Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 12 11-04-2007 10:27 AM
Painted brick James Napier Building Envelope: Home Inspection and Commercial Inspection 19 05-26-2007 12:30 PM
Brick David Banks Building Envelope: Home Inspection and Commercial Inspection 5 05-19-2007 06:06 PM
Brick displacement Jeff Eastman Structural Components: Home Inspection and Commercial Inspection 6 05-10-2007 07:44 PM
vB.Sponsors
Ad Management by RedTyger
