Old 04-26-2007, 05:35 PM
dan orourke dan orourke is offline
Commercial: Stucco interface with flat work
Home inspection
Old 04-26-2007, 08:00 PM
Re: Commercial: Stucco interface with flat work
Depends.
If on frame, stucco should clear landscape (earth) by 6" and hardscape (concrete flatwork) by 4".
If on masonry or concrete, and the stucco is less than 5/8" thick and fully adhered (as it should be), then the stucco can continue down into earth.
Similar Threads
Stucco Jeff Eastman Exterior Systems: Home Inspection and Commercial Inspection 3 04-12-2007 07:01 PM
More Stucco question Jeff Eastman Exterior Systems: Home Inspection and Commercial Inspection 1 04-12-2007 04:02 PM
Commercial zone system, Kevin VanderWarf Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 04-07-2007 03:05 AM
Quality of work Eric Van De Ven Electrical Systems: Home Inspection and Commercial Inspection 2 04-04-2007 07:26 AM
vB.Sponsors
Ad Management by RedTyger
